To those who have lots of experience designing crossovers: I've looked at several 2-way systems like the eros from speakerbuilder.net, and the waveguide project at Zaph audio, and when I simulate the crossovers, the tweeter cutoff points seem very high. Like 11 KHz or so but the design says the tweeter and woofer are crossed at like 2 or 3 KHz. Whats up with this?
#2 |
What Simulation package are you using?
I have good luck replication both speaker workshop and LPG-cad (sp) in soundeasy. HTH Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
#3 |
I actually wrote out the transfer function for the filter and found the pole. I then checked these results using PSpice and found the half power points and they matched the work I did on paper.
#4 |
Actually for these crossovers I wrote out the transfer functions by hand to find the crossover points, the poles of the function. These didn't seems right to me so I check these results using PSpice and I got the same exact results. Half power point was way too high. What do you guys make of this?
#5 |
oops, sorry for the double post.
#6 |
Could you be mixing radians with Hz? Just a quick thought.
#7 |
#8 |
I guess the waveguide boosted the frequencies below 11K so he had to cross it there.
jimangi- nah i pulled out the 2*PI |
#9 | |
#10 |
Stevez,.....Try and calculate/sim a 2.order LR filter ..... and dissregard the inductor ....
| Crossover Question | ajh | Full Range | 10 | 21st September 2007 06:06 PM |
| Crossover Question | ppfred | Multi-Way | 3 | 10th May 2006 09:16 AM |
| Crossover Question | cantskienuf | Multi-Way | 4 | 13th October 2004 09:59 PM |
| 2-way crossover question | dikarner | Multi-Way | 3 | 16th April 2004 05:52 PM |
| crossover question | Rodtay | Multi-Way | 3 | 7th August 2003 11:35 AM |
| Page generated in 0.09595 seconds (81.34% PHP - 18.66% MySQL) with 10 queries |
