Old 9th May 2007, 09:15 PM   #1
pboser is offline pboser  United States
Default Stereo open baffle
Has anyone ever tried putting both channels on one wide open baffle? Am I right that the cutoff frequency would be the same as if it was one driver on that baffle? Would locating the drivers closer to the edge be a problem? What other implications am I missing?
Thanks,
Pete
Old 9th May 2007, 09:35 PM   #2
Tenson is offline Tenson  United Kingdom
Wouldn't it basically be another wall at the end of your room with some drivers in it by the time it is big enough for decent stereo separation?
Old 10th May 2007, 12:28 AM   #3
Default stereo separation
I suppose you're right, though maybe in a small room nearfield it might work. Or, maybe I should just go mono for this setup!?!
Old 10th May 2007, 12:44 AM   #4
What about an in wall system? A pair of long ribbons like the B&G RD series (AKA Radia) and a couple of 12" or 15" woofers in boxes hidden in the corners of the room. Xover around 200Hz.
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
Open-baffle baffle length matejS Multi-Way 2 21st September 2010 04:49 PM
Murphy baffle radios [ open baffle ] keithpeter Full Range 10 11th September 2007 07:59 PM
what effect does baffle have on open-baffle system? kappa546 Multi-Way 6 24th January 2006 10:21 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Page generated in 0.07832 seconds (73.00% PHP - 27.00% MySQL) with 10 queries
