I have read Jim Griffin's paper on near field arrays with some interest, and I would like to have a go at building a pair.
Jim stipulates that the centre-to-centre distance of the tweeters should be 34mm. I am looking at purchasing some tweeters that seem good value and good quality, but they have an outside diameter of 46mm. I could shave some of the baffles off, but this would be time consuming and difficult to do neatly. Please could someone explain what the affect of the larger c-to-c distance would be? I might just live with it. The arrays will be in a smallish room (12ftx12ft), and I would imagine that the listener would be in near field at all times. Thanks |
#2 |
The short answer is one wavelength = 7.5kHz instead of 10KHz. |
#3 |
Email me. I built a large line array using dome tweeters with comb filtering not starting until a pretty much inaudible 15Khz.
I can show you photos and show you how to do it. Calipso@epix.net
Youth is wasted on the young. |
#4 | |
The closest the ND16FA can be mounted to one another is 1.25" (the flange of these is 1.25"). Since you are in the nearfield, multiply that by two and divide the speed of sound by it (13,397inches-second/2.5=5358.8hz). Comb filtering will begin at 5358.8hz for the 5/8" dome... The closest the ND20FA can be mounted to one another is 1.75" (flange is 1.75"). 13397/3.5=3827.7hz. In the far field, loudspeakers must be within one wavelength of one another. In the near field (line arrays operate in the near field), loudspeakers must be within one half of the wavelength of one another. The only way to ameliorate the situation is to lower the number of places where the diaphragms are seperated. Dome tweeters centers are at the very center of the dome, while Ribbon tweeters centers are at the middle of the entire length of the diaphragm. The area below the edge of the top ribbon and the area above the edge of the bottom ribbon is the only area you have to worry about for CTC spacing for ribbons, as opposed to half the facade for dome tweeters. For this reason, Ribbons are a much better choice for line sources. You could make the situation even better by just going with a single line source such as a BG RD75. |
#5 |
BG RD75.
Trade in a theoretical demon for a worser demon. hehe
#6 |
My Dear Thad,
Of course you're are 100% correct---AS FAR AS YOU GO, which isn't far enough to solve this little enigma. I use the Dayton ND20FA tweeters. I notice that you didn't bother to email me to find out how I might have done this. You just jumped off completely half-cocked assuming that I couldn't possibly be correct. You state: "The closest the ND20FA can be mounted to one another is 1.75" (flange is 1.75"). 13397/3.5=3827.7hz." However you obviously don't own any of these. You have also not read carefully Jim Griffin's line array paper, nor have you actually spoken to Dr. Griffin about this. You obviously have not built one of these line arrays with the tweeters. Get a copy of the paper here: http://www.audiodiycentral.com/awpapers.shtml I quote from page 13: "For the tweeter line very close center-to-center spacing is difficult to attain as very small circular drivers would be necessitated for either the one wavelength or especially the half wavelength criteria. Consider operation to 20 kHz where one wavelength is 17.2 mm (0.68”) and a half wavelength is only 8.6 mm (0.34”). Without regard to their surrounding flanges, dome tweeters are available in 25 mm (1”), 19 mm (0.75”) and 13 mm (0.5”) diameters. Hence, with any mounting flange allowance at all, the one or half wavelength c-t-c criteria are very difficult—if not impossible--to satisfy at 20 kHz. But, if we relax the c-t-c criterion, more secondary lobes would appear in the 10 to 20 kHz frequency range. Fortunately, in this octave the ear is less sensitive (per FletcherMunson curves) so any secondary lobes likely would be less audible to the listener. Thus, if one wavelength spacing at 10 kHz is adopted as a compromise, then tweeter spacing would need to be 34.4 mm (1.35”) c-t-c apart. While more off axis secondary lobes would be generated in the far field, small flange tweeters are available to meet this dimension. The tradeoff is possible sound degradation from comb lines near 20 kHz. " My line array cuts the flanges so that the C-to-C distance is closer to .9 inch. Using the 1 wave length criteria: 13560/.9= 15066hz. Additionally my lines are designed to be listened to very close to the edge of the nearfield-farfield boundary. Since I have actually built such an array, and you have not, I assure you that sitting at about 9-10 feet from the tweeter portion of the array, using cut flanges with the tweeter array at about 34 inches in length, THERE IS NO AUDITORY EXPERIENCED COMB FILTER DISTORTION(even standing and moving my head up and down). You can rely on your theoretical discussion if you want. I will continue to rely on my own and all who have listened, auditory observation. Until you have actually built a line array of this design, quite honestly, you don't know whereof you speaketh. Zarathu
#7 | |
Combing is an obnoxious artifact, very annoying even in the 10 -20 Khz range, especially vertically oriented...an obvious flaw in multidriver arrays
"...His brain is squirming like a toad..." Jim Morrison |
#8 | |
I also NEVER debated whether comb filtering was audible or not, I simply stated when it should occur. ...and yes I have read Griffin's white paper on line arrays. It calls for CTC spacing of <1 wavelength in the far field and CTC spacing of <1/2 wavelength in the nearfield (of which line arrays propagate). I contemplated building one myself using those VERY same tweeters (Yes, I read the white paper thoroughly and did ALL THE MATH) and decided an ESL with a dynamic bass array would've been a more economic approach to a line source with greater sound quality potential. I have a hard time believing you cut the tweeters down to .9" wide...as the cutout is 1-5/16". Could you provide some pictures please? ND20FA-6 Specifications: *Power handling: 15 watts RMS/30 watts max *VCdia: 3/4" *Impedance: 6 ohms *Re: 5.2 ohms *Frequency range: 3,500 - 25,000 Hz *Fs: 1,800 Hz *SPL: 92 dB 2.83V/1m *Dimensions: A: 1-3/4", B: 1-5/16", C: 3/4". Either way, with a flange measuring .9", comb filtering would begin at 7442.8hz in the nearfield...which I assume the threadstarter would envelop himself in as nearfield propagation is one of the line arrays greatest benefits (very little floor-ceiling reflections and -3dB for every doubling of distance)...I dont understand why you'd construct a line array and purposely listen to it outside of the nearfield? hmm... .9(2)=1.8, 13397/1.8=7442.8hz ^What of these facts are you disputing? Please don't act arrogant and assume things (specifically that my posts were a threat against you, we're hear to inform people not force our beliefs on others) |
#9 | ||
What have I claimed or debated that is false? Please inform me...I AM CORRECT, YOU'RE WRONG, YOUR DESIGN IS FLAWED, PLEASE ACCEPT THAT AND MOVE ON. I have used the information currently available, to come to perfectly plausible conclusions. You obviously have not taken the time to construct your line array "optimally" or engineer it "perfectly" as you seem to claim you have...why should we allow you to spread your ignorance and arrogance without a response? How many line arrays have you constructed? Have you built one with an optimal arrangement and compared them subjectively and objectively? Quote:
* Compact neodymium motors have low stray field * Ferrofluid enhances power handling and helps damp resonance * Front-mount pressfit design * Center-to-center spacing as low as 1-3/4" * Extremely flat and extended response *Dimensions: A: 1-3/4", B: 1-5/16", C: 3/4". The cutout is larger than .9"... |
#10 | |
If you havent, I wouldn't consider your biased opinion a reliable source. |
| Tweeters for line array? | maghen | Multi-Way | 8 | 11th December 2008 08:09 PM |
| A line array using HiVi B3S or B3N & Apex Jr tweeters? | Brisso57 | Multi-Way | 6 | 10th August 2007 08:02 PM |
| Mounting tweeters over the woofer in a line array. | GuyPanico | Multi-Way | 8 | 28th June 2007 11:10 PM |
| FS HUGE Line Array Cabs/W Tweeters | Turboegt | Swap Meet | 9 | 27th September 2005 02:22 PM |
| Line array tweeter line - On left or right? | dhenryp | Multi-Way | 4 | 9th March 2005 11:35 PM |
| Page generated in 0.16426 seconds (86.09% PHP - 13.91% MySQL) with 10 queries |
