Old 9th May 2007, 12:27 PM   #1
Vix is offline Vix  Yugoslavia
Vix's Avatar
Default B&C 15 PK 40 good for OB?
I've searched but couldn't find detailed technical data about this speaker. A local shop sells these for around 140 Eur, but they don't provide t/s parameters.
I'd like to know if this speaker can be used for an Open Baffle (as a bass helper to Visaton B200).
Thank you very much,
Vix
Old 9th May 2007, 12:37 PM   #2
zeonrider's Avatar
Default Hi !!!
Empfehlung:
60 Liter BR-Box
mit 2 Stück TR 100
ab 50 Hz (-8dB) 15 PK 40 EUR 205,00
380 mm Tiefton-Lautsprecher mit hohem Wirkungsgrad mit guter Linearität bis 1,5 kHz.
Belastbarkeit: 400/800 Watt
Resonanzfrequenz Fs: 47 Hz
Übertragungsbereich: 50 bis 2000 Hz
Nennimpedanz: 8 Ohm
Güte Qts=0,31 (Qes=0,33 Qms=5,1)
Äquivalenzvolumen Vas: 140 Liter
Gleichstromwid. Re: 5,1 Ohm
eff. Membranfläche Sd: 855 cm2
Kennschalldruck: 99 dB (1W; 1m)
max. Auslenkung Xmax: +/- 4 mm
Abmessungen: runder Lautsprecher mit 394 mm Durchmesser
Lochkreisdurchmesser: 374 mm
Schallwandöffnung: 355 mm
Tiefe des Lautsprechers: 162 mm
Very good bass , good sound !
Regards zeoN_Rider
Old 9th May 2007, 01:14 PM   #3
Vix's Avatar
Thanks!
Qts=0.31 looks quite low for an OB...
What makes the good guitar pickup sound so good? darkfenriz Instruments and Amps 15 1st March 2009 11:46 PM
Good switch for Stepped attentuater, Good cheap RCA jacks pjpoes Parts 20 10th March 2005 08:47 PM
Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? XteveX Multi-Way 7 28th April 2004 04:05 AM
Page generated in 0.07648 seconds (73.92% PHP - 26.08% MySQL) with 10 queries
