Old 8th May 2007, 10:50 AM   #1
crissty is offline crissty  Greenland
Default Suggest if i can bridge
I have 4 scoop bins all loaded with RCF G400, and have a crest 8001 for driving all 4 scoops, and its great.
G400 are rated at 1000W (AES Power Rating) and crest 8001 is 1250W @ 4ohms / ch, (i.e. 625W is being pumped to one driver).
Can I bridge 8001 for driving 2 scoops, which would pump 1250w per driver, would it be safe please suggest, i usually set the output of amps just touching the clip led.
Old 8th May 2007, 11:06 AM   #2
Did it Himself
richie00boy's Avatar
Best consult the amp manual or connection info given on the amp itself. I would imagine the amp is already internally bridged. Are you sure you understand the power rating correctly? 1250 watts into 4 ohms per channel usually means each channel is 1250 watts, so the total for a 2-channel amp is 2500 watts.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 8th May 2007, 11:42 AM   #3
yes i referred the manual and it specifies the foll.
720W - 8Ohm Stereo
1200W - 4 Ohm Stereo
1400W - 2 Ohm stereo
2250W - 8Ohms Bridged
2800W - 4 Ohms Bridged
One should use a amp rated at 1.2-1.5 times the rated power of driver.
I feel i am not using the full capacity of the Driver, and still i want to be safe before trying it out.
Old 8th May 2007, 01:58 PM   #4
any suggestion ??????????????
i would like to try using in bridge mode, if its safe for my Drivers.
Old 8th May 2007, 02:20 PM   #5
Did it Himself
Are you saying you normally have all 2 bins wired in parallel per channel and they are 8 ohm bins? So you are loading each channel with 4 ohms?
And now you want to try driving one pair of bins again at 4 ohms total, by the whole bridged amp? If so then from the spec it appears that you can do that.
But what then will you power the unused pair of bins with?
Old 9th May 2007, 02:55 AM   #6
Thanks,
I will have to get a new amp for driving other two.
I will give it a try today, by the way how do i calculate how much db would i gain by doing this.
Old 9th May 2007, 10:25 AM   #7
Did it Himself
+3dB SPL as you are doubling power input.
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 07:22 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Can anyone help me understand why my PS has a bridge within a bridge? schematic enc qboneus Power Supplies 5 5th March 2006 12:34 PM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Page generated in 0.13408 seconds (83.46% PHP - 16.54% MySQL) with 10 queries
