L-R 12db/oct tweeters reversed or not? - Page 4 - diyAudio
Old 4th February 2013, 08:13 PM   #31
There is no second order Linkwitz-Riley.
Deep Throat
Old 4th February 2013, 08:19 PM   #32
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
no, so they say
I think it's originally 'transformed' from Bessel filter function
this can be handled in passive crossovers
maybe why they say it's really more like 8 or 10db than it is 12db
but will you notice the difference on a graph
but active 12db 'L/R' crossover .... yes could mean trouble
has to be 'compensated', or it could have unintentional peak in xo point
but I clearly remember a very skilled man saying....'what does it matter I don't know anything about BSC when I use measurements'
I shall not tell who said that
Old 5th February 2013, 07:01 PM   #33
oszkar is offline oszkar  Romania
HW 3/120 NG - 8 Ohm will theese work?
Old 5th February 2013, 07:07 PM   #34
balerit is offline balerit  South Africa
balerit's Avatar
Deep Throat
You got to be kidding, right!
Old 5th February 2013, 08:22 PM   #35
Correct.
Now that I have definitively answered the six-year-old question, oszkar, please start your own thread.
Old 5th February 2013, 08:51 PM   #36
tvrgeek is offline tvrgeek  United States
The L/R crossover is defined as the cascading of two second order Butterworth filters. By definition, it is 4th order. Period. Now, one can use the idea of spreading the centers and higher Q to any order filter if it works for them. Technically, the crossovers I have built that try and approximate an L/R crossover by incorporating the driver natural rolloff are not L/R crossovers. One does not have the ability to control the Q. They are "inspired by" the gentlemen.
Old 6th February 2013, 05:48 AM   #37
Default Threading
Ok! How do I open a new thread! I was lookint for the past 5 minutes! Thanx!
Old 6th February 2013, 07:46 AM   #38
go to main menu, and where you want it, then top left you see 'New Thread'
moderation
Old 8th July 2016, 09:23 AM   #39
charlesp210's Avatar
Deep Throat
LR2 is a well known crossover, and described by Linkwitz himself:
Crossovers
4) - 2nd order Linkwitz-Riley filter (12 dB/oct, LR2)
I believe I have seen it described in earlier writings by Linkwitz as well, along with LR4, LR6, LR8. And other authors in JAES 1979-1989. When the order is divisible by 4 the polarity of both drivers is the same, otherwise the polarity of one side must be inverted.
I'm not exactly sure what the formal definition of LR crossover is, I think a cascade of 2 maximally flat filters or cascade of 2 filters having Q of 0.707. NOT only a cascade of 2 second order butterworth.
Can a toroid be reversed? leadbelly Power Supplies 5 2nd September 2007 06:34 AM
reversed signal polarity? G_a_r_e_t_h Car Audio 19 14th September 2006 04:01 AM
Class TD reversed engineering possible? lumanauw Class D 19 10th February 2005 01:17 PM
Stereo Sounds Different To Reversed mrfeedback Everything Else 19 17th March 2003 10:40 AM
Copyright 1999-2017 diyAudio
