L-R 12db/oct tweeters reversed or not? - Page 3 - diyAudio
Old 4th February 2013, 07:15 PM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
your impedances will be very low
and not match crossover at all
big problem
Old 4th February 2013, 07:16 PM   #22
balerit is offline balerit  South Africa
balerit's Avatar
Originally Posted by tinitus View Post
I have never experienced any 2way that shouldn't have reversed tweeter
with 3ways, it's always been reversed midrange
that said, I haver never owned or built any speaker without some kind driver offset
or else I would most likely tilt the whole speaker backwards
2-way second order filter, tweeter reversed. 3-way second order, tweeter normal midrange reversed.
Old 4th February 2013, 07:19 PM   #23
oszkar is offline oszkar  Romania
ok! Thanks allot!
Old 4th February 2013, 07:22 PM   #24
then I guess all my speakers must have had 2.order crossovers
Old 4th February 2013, 07:22 PM   #25
tvrgeek is offline tvrgeek  United States
MEASURE. If you have a big notch at the crossover, then you need to switch it. This is the only sure way as the one rule if speakers is "in depends"
Old 4th February 2013, 07:26 PM   #26
So that crossover of the BRAUN L630 will work with theese drivers?! they are al 63V, that should cover it of what i know... No?!
Old 4th February 2013, 07:55 PM   #27
I mean, the caps are 63v!
Old 4th February 2013, 08:01 PM   #28
if you already have all those parts from whoknowswhere, try it
with mid drivers i series
and tweeters in series
woofers...? maybe better in paralel
but I would not recommend to buy anything to do this
Old 4th February 2013, 08:07 PM   #29
I want to make a replica of the original crossovers with cut frequencies at 1500 and 8000hz! I do not know where every thing is placed, and I would have put into them a ceramic resistor and tweeter protection aswell a PTC i would say!
Old 4th February 2013, 08:09 PM   #30
If anyone can help me with a drawing of how everything is placed, values I would apreciate it! 2nd order 3 way!
Can a toroid be reversed? leadbelly Power Supplies 5 2nd September 2007 06:34 AM
reversed signal polarity? G_a_r_e_t_h Car Audio 19 14th September 2006 04:01 AM
Class TD reversed engineering possible? lumanauw Class D 19 10th February 2005 01:17 PM
Stereo Sounds Different To Reversed mrfeedback Everything Else 19 17th March 2003 10:40 AM
Copyright 1999-2017 diyAudio
