Old 6th May 2007, 04:48 PM   #1
Default And again, Yet another Tweeter question
I have these Sansui speakers I have been upgrading the cross-overs. Come to find out the horn tweeters are shot. I believe they are ALNICO horn's T-149 12ohm 40w.
I would like to rebuild them. If not, i have no clue on a replacement.
The cross-overs I rebuilt had Rubycon caps that i pulled and replaced with Nichon's i guess i might have over heated the posts on the tweeters. The tweeters are 12ohm and the Cap for them is a 100V 2.2uf Nichon. I don't know how to replace the diaphragms and deal with the 12ohm issue because most replacement diaphragms are either 4,8,16ohm so i guess i would need to adjust the cross overs, which I have no idea how to proceed. I have dis-assembled the tweeters and found the lead wires intact so i know a simple re-solder wont fix them. any ideas would be great. Thxz J Rogers
Old 6th May 2007, 07:49 PM   #2
Speakerholic
Cal Weldon's Avatar
Hi J,
A 12 ohm tweeter isn't that hard to replace. You can add an extra 4 ohms to the circuit with a series resistor and an 8 ohm tweeter. Or you can change the value of the cap to suit a new 8 ohm unit.
Have you checked to see if a replacement diaphragm is available?
If not you either look for them on ebay or you find another tweeter the same size and adapt your XO and L-pad to it.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
And again a Tweeter question ChocoHolic Multi-Way 20 3rd December 2007 02:49 PM
Tweeter question 3-LockBox Multi-Way 6 15th June 2007 09:34 PM
Tweeter crossover question. sugarn Multi-Way 8 27th May 2007 02:29 PM
tweeter question toque_101 Multi-Way 7 7th March 2004 12:36 AM
Page generated in 0.06602 seconds (68.81% PHP - 31.19% MySQL) with 10 queries
