I have built a pair of speakers using the ScanSpeak 12m4631G midrange driver and they sound really good, but there is a noticeable dip around 2-3KHz that makes vocals sound a bit recessed. I also notice this same dip, though less pronounced, in the response measurements Zaph took of some of these drivers. ![]() I think part of the issue may be that I did not countersink the driver, so I will try that. It is also, however, partly due to having the Xover near-by and the lead-in to the crossover drops that dip down even more But if it is still an issue after recessing the driver, is there any way to correct for that dip using passive filters?If the whole level has to go down 3-4dB to do it then so be it (thinking band pass kind of filter). Or maybe I can actually make a resonance at this frequency? But I am not sure exactly how to do all this with passive filters so advice is appreciated please! I realise I could correct using an active filter between CDP and amp but I don't want to have to do that since I'd like the speakers to be 'stand alone'. Cheers guys! Edit: Zaph, can you recall if you countersunk the driver when you took your measurements? ScanSpeak's own PDF does not show this dip. |
#2 |
Hi Tenson, it's not so much a dip at 2.3k but a rise from 600 - 1.6 k of 3db. See how recessing the driver effects things. A diagram of the crossover would be helpful, with xo freqs.
Geoff |
#3 |
Hi Tenson. I suggest u to measure off axis response as well. If the dip dissapear off axis, I'll live with it.
Try to correct diffraction issue with EQ, might create power response irregularity. |
#5 |
Yes I did BD simulations, I don't think it is that. I am beginning to think it is more complex such as phase issues and inconsistencies between the tweeter I first measured and the one I added the network to. Don't worry about it for now, I must rethink the whole thing I think. |
#6 |
Actually I do have a question if I may.. is it just me who has found SpeakerWorkshop does not model notch filters well? At least, I have tried two different notch filters in this project (at different frequencies and Q) and neither were anywhere near as effective as SpeakerWorkshop made out they would be. I had to use about double the resistor value to even get a noticeable dip in the response.
#7 |
Are you modeling inductor DCR, and what type of capacitor are you using?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#8 |
Hi, yeah I was modelling the inductor DCR, it was not big enough to mean I needed double the resistor value anyway though.
I was using standard aluminium electrolytic caps. Are these not suitable? In fact I have sometimes wondered, since music is AC, surely electrolytic caps, directional as they are, are not suitable? But they do seem to work fine in most cases! I don't like to splash on polyprops or whatever until I know the Xover is working well. ..and sometimes I just don't bother at all! |
#9 |
Hi Tenson,
We should never use standard electrolytic caps in a xo. If larger values are required use bipolar, or non polarised electro, and if passing higher freqs should have smaller non electrolytic caps in parallel. A standard electrolytic has a diode type action, and can explode if reversed polarised. Geoff |
#10 |
I know it is not best practice... but they do seem to work just fine for things like simple tweeter Xovers. In fact I have never had any problems using polarised caps!! Its seems odd to me, but anyone with a good electronics head care to explain why they seem to work fine in most cases?
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order | Hybrid fourdoor | Multi-Way | 3 | 11th July 2004 09:16 PM |
| dc offset correction pot | mirlo | Solid State | 5 | 31st July 2002 10:22 PM |
| Page generated in 0.10486 seconds (81.12% PHP - 18.88% MySQL) with 10 queries |
