New to the hobby. I recently assembled a speaker kit with a Peerless woofer:
Peerless 850122 woofer: 6.5", 17cm, Polypropylene cone with Low Loss Butyl Surround. During assembly a small wood splinter lodged in the seam where the bowl-like cup at the center of the woofer meets the cone (I assume it's the cone--the inward-slanting surface sitting in the rubber outer ring). Very small splinter--can't get it out with a fingernail. Any reason to get it out? If so, what's the best way? I'm afraid to dig around with a needle. Thanks for your suggestion! |
#2 |
use some smt tweezers.
and retsrain the cone just in case its firmly lodged in place.
hoping to pick up some things. |
| 4 ohm or 8 ohm woofer in 2 way | mmgando | Multi-Way | 0 | 4th December 2007 07:14 AM |
| Do I still need a woofer? | fossilfool | Subwoofers | 3 | 17th May 2007 12:16 PM |
| diy sub-woofer | takashi | Subwoofers | 3 | 19th August 2003 09:16 PM |
| the best mid-woofer? | joz | Multi-Way | 4 | 19th March 2003 08:19 AM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 01:30 AM |
| Page generated in 0.22908 seconds (100.00% PHP - 0% MySQL) with 9 queries |
