Old 4th May 2007, 07:05 AM   #1
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Default Safe To Add Another Bass Port?
Hi everyone.
I have a noob question about adding bass to my speakers.
Would it be safe to add an extra bass port to my speaker cabs? They are front ported already but the bass output is fairly pitiful and I am wondering if I could cut another port, as larger cabs may be difficult due to WAF.
Regards, Lee.
Old 4th May 2007, 04:24 PM   #2
sreten is online now sreten  United Kingdom
Hi, The short answer is no. Another port will make things worse. /sreten.
Old 4th May 2007, 09:05 PM   #3
Speakerholic
Cal Weldon's Avatar
Better to use an equalizer than to try and alter a cabinet. If the cabinet is designed correctly, adding another port won't help as sreten has said.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th May 2007, 12:26 AM   #4
Those are the original woofers the cabinets came with, right?
Nobody just bought a replacement speaker for a broken woofer and just put it in the cabinet?
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 5th May 2007, 09:07 AM   #5
Thomo's Avatar
Thanks for the info guys. I thought this might be the case, I guess I'll have to build bigger cabs.
They are fully original speakers, Tannoy Dual Concentric 12". They need a really big box to breathe properly.
Thanks again, Lee.
Bass Reflex port for Usher 701 kit nippontiger Multi-Way 7 16th September 2008 03:11 PM
Downwards Bass port in a Bookshelf Dan_Steele Multi-Way 3 25th July 2007 04:04 PM
Bass reflex port question Javachip Multi-Way 12 11th April 2006 12:11 PM
Port position on Bass cab Gubbe Instruments and Amps 1 17th February 2006 03:40 PM
what the max Air velocity of bass reflex port? Audist Multi-Way 4 7th February 2005 08:43 PM
Page generated in 0.07823 seconds (73.93% PHP - 26.07% MySQL) with 10 queries
