Old 3rd May 2007, 11:04 PM   #1
Default Anybody got a good equalizer design?
I want to build a new pair of speakers and I think I'd like to try out bi-amping them. I was also thinking that instead of using standard active crossovers that I'd build an equalizer that's split into high and low frequency outputs so that I'd be able to crossover and equalize the signal in a single stage. I've been looking for a good equalizer design that I could adapt, but all the designs I've been able to find were designed with the intent to be as cheap as possible for home studio use. Does anyone know of a really high-quality, low distortion equalizer design?
Old 4th May 2007, 01:54 AM   #2
ttan98 is offline ttan98  Australia
go to this webite,
http://mysite.verizon.net/vze3xvxs/audio/
and also go to market place on this forum, group buy and under active filter gainclone. The design is from Rasmussen.
I have the gerber file for his design, and will proceed with the manufcture if enough interest in a group buy. A small run is too expensive in Australia, if you can do it where you are I am interested. At least 2-4 boards.
contact me if you want to proceed.
Good pcb design luka Class D 32 26th May 2007 02:46 PM
Graphic Equalizer design HELP needed hrg2112 Solid State 4 21st December 2006 07:06 PM
Good design? icebear Tubes / Valves 1 30th September 2004 12:44 PM
Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? XteveX Multi-Way 7 28th April 2004 04:05 AM
Good amp design? technics Solid State 6 17th June 2003 01:04 AM
Page generated in 0.05987 seconds (69.68% PHP - 30.32% MySQL) with 10 queries
