Wiki on bracing
Wiki on bracing
Old 7th May 2007, 03:37 PM   #41
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Looks fine. And editable at all time.
/Hugo
Old 7th May 2007, 04:06 PM   #42
Tenson is offline Tenson  United Kingdom
"The Hz of a panel resonance is inversely proportional to the square (?) of the panel size, eg if a panel size is doubled, the frequency of a resonance increases by a factor of 4(?)."
Are you sure panel resonance goes up by having a bigger panel? Think of Rolf Harris and his wobble board. A bigger board produces a lower frequency when it is flexed.
Perhaps you are referring to the thickness of the panel?
Old 7th May 2007, 06:55 PM   #43
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Wiki on bracing
Since it is inversely proportional the 4 needs to be 1/4 for the sentence to make sense.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th May 2007, 07:32 PM   #44
frugal-phile(tm)
planet10's Avatar
Wiki on bracing
I have added some picture links, but haven't been able to figure out how this wiki actually lets you display them.
dave
Old 7th May 2007, 08:40 PM   #45
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
It's certainly not the square.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 8th May 2007, 07:10 AM   #46
rick57 is offline rick57
"Since it is inversely proportional the 4 needs to be 1/4 for the sentence to make sense"
Uh, yes: corrected thanks
Old 5th March 2008, 07:47 AM   #47
USXX is offline USXX  Denmark
Default Wrong equation
rick57, the equation you posted is incorrect. There is a problem with the brackets. The correct equation is:
f = (pi/2) * sqrt(D/p) * [(1/a^2) + (1/b^2)]
This makes sense and can be found several places in the literature (e.g. James K. Iverson, "The Theory of Loudspeaker Cabinet Resonances", Journal of the Audio Engineering Society, vol. 21, April 1973).
Let me also remind you that mass density is mass per volume, not mass per length.
The wiki should be updated!
Wiki on bracingHide this!Advertise here!
Does A Box Like This Need Bracing? sdclc126 Subwoofers 10 12th May 2006 02:31 AM
how much bracing is enough gwgjr31 Subwoofers 1 5th May 2006 07:57 AM
do I need bracing for a 15L BR? RockysDad Full Range 12 11th August 2005 08:18 PM
enough bracing?? Chris8sirhC Multi-Way 3 31st January 2004 09:16 PM
OT (badly) Wiki Wiki jackinnj Everything Else 0 26th June 2002 05:50 AM
