#1 | |
BTW how does one determine if the woofers one has are suitable for open baffle? High Qts? How high? 0.7? or more?
...still looking for the holy grail. |
#2 |
No ..I don't use a subwoofer.....I don't need that.
I have another setup only for home theater. Martin King have the same woofers into open baffle and the active setup provide 97db on 35hz.He tryed first Dayton woofers but the personal taste was Alpha's. About qts...in fact is a matter of personal taste. You should try to listen first woofers with 0,4-0,7 and after that you should go to Alpha's 1,26....but do that quiqly. Some have a good reports using 0,5-0,7 and have a personal taste because use so called "quality of the bass"....but loose that cream of music. But...I myself,Martin and many others owners have tryed all these qts. The Alpha's do the job stunning.Bass is clean,full,a little soft,(that I appreciate to Alpha's)avoiding interference with Supravox,the instruments in right in my face..... You should try to listen to have a good impression.
"I'm glad I can build my own mistakes." |
#3 |
This is OT but related to felix's OB subwoofer so forgve me if I post this here.
Felix, I have a 4 12" woofers handy. Qts 0.44 Qms 5.1 BL 7.8Tm, Fs 17Hz Vas 380 liters MMs: 73gms Voice coil height: 30mm Air gap Height: 10mm Resistance: 3.1 ohms (4 ohm nominal). Presently they are in large sealed boxes (about 65-70 liters each) and I was hoping to reconfgure them into smaller boxes. I was thinking Apreioic till I saw your OB speakers. I understand OB will drop the Max SPL I will get by about 6db bot the bass should have better definition.
#4 |
4 pieces of 12" into (two) open baffle don't think it goes very well.
First I wanted to try Peerless 12" sls ....but I wanted to make a very short compromise....and that is really woofers. Another option will be if you will use 4 piece 12" only into one open baffle or dipole sistem.That means 8 drivers only for bass.
#5 |
I think OB lets a driver play more or less as intended by the manufacturer (most drivers are measured in an OB). It just needs to be large enough and it works... I do have the impression that large bass drivers perform better in such small baffles (I tried several small drivers and even with eq. I didn't like the results...).
I just built one proto (lucky I got the wood for free...) and immediateley loved it. After that I measured and saw it also measures fine... I would always recommend building some kind of proto first... The drivers I use (JBL 2220A) have very very low QTS, so after all the stories I expected it to need lots of EQ. But it doesn't! I don't know what to believe anymore, right now I think there are many drivers suitable for the job....(more than people claim...) Also I think there are many ways to rome, if you have more from this you can have less from the other. It's the balance that counts. For instance if you have a smaller baffle, use larger drivers or eq. If your driver has high Qts it can be a smaller driver/less eq. I'm starting to think if you just build something on a good hunch you're close enough to get it right anyway. I must add that I presume most of the above (and a bit of experience) but I didn't try everything yet, and certainly don't claim to be some kind of OB guru.... |
#6 |
@v-bro
Absolutly true.
#7 | ||
I bought 30 year old, but recently reconed drivers for 50EUR./each. containing the ingredient 'alnico' I started with the baffle only, than added 15cm sides to make a small u-frame, than made the real thing larger than necessary and it turned out precisely right Quote:
Be building more of 'em, much much more next with a really high Qts driver |
#8 | |
So 2 12" per side is not a good idea. well plan b for me was a isobarik box.
#9 | |
#10 | |
Well from the measurements and from the experience I have nothing to complain about. I think a higher Q driver could have been smaller size and lower sensitivity. I just thought I'd start with overkill to create the necessary headroom to clean it up afterwards. But I don't feel I should change anything, like I said I'm totally satisfied! I don't even feel like using eq to boost the lowest freqs up. The driver has 40hz Fs and the system goes well below 50hz, which I find deep enough... Bottom line is that the balance here seems quite allright, eventhough I think some adaptations are needed with low Qts drivers. But I see no problem in using low Qts drivers. High Qts will perhaps only give slight benefits... I can only speculate on this for the moment, perhaps someone can explain it better or give a few nice examples? Pictures or measurements...or a link to.... |
| Format and Audio Ripping Discussion Split From Blowtorch Thread | john curl | Digital Source | 109 | 1st August 2008 04:56 PM |
| BSC discussion - split from Usher two way thread | ch83575 | Multi-Way | 32 | 9th February 2007 11:38 PM |
| Page generated in 0.11965 seconds (81.00% PHP - 19.00% MySQL) with 11 queries |
