#31 | ||
2. That Dayton woofer looks well made but how ouwld it compare to old favs like the NHT1259, Bhrama, Shiva, Tumult or any of the drivers from Eminence (Kappa 15), Selenium (SLF 15), or even pro drivers like the JBL 2235 or Peavey low rider/pro rider subs.
...still looking for the holy grail. |
#32 |
I think if there's enough surface you don't need optimal Q. As long as you have suffiecient hub and surface anything will work, I think preferrably high Qms and Qes.
Allthoug my 'pro' seventies JBL 2220A have very low Qts and work quite nicely in a medium sized room and pretty large baffle (with sides) and the baffle placed in contact with the floor. |
#33 |
Can a maths expert tell us what happens to Qts and spl figures if we change a cone with another one with knowm mass , surface area and (expected ) resonance frequency ?
If you ask why , it's to guess what will happen if we graft a bigger cone on to a smaller frame. Say an 18 inch cone on to a 12 inch frame with various mods to the frame. Qts should go up and Fs should fall , possibly Qms should go down. Sensitivity would suffer most I think. Outlandish ... yes ! The web is full of far more outlandish things !
AM |
#34 |
Trying to narrow down my search for bass drivers going by experience or specs which would seem to be better? Ficar audio SSD18
DUAL 1 | DUAL 2 Fs: 24.7 Hz | 24.3 Hz Re: 0.75 Ohms/coil | 1.5 Ohms/coil Qms: 4.88 | 4.96 Qes: .75 | .69 Qts: .65 | .61 Mms: 296g | 308g Cms: 0.14mm/N | 0.14mm/N Sd: 1210cm^2 | 1210cm^2 Vas: 285 l | 285 l Spl: 89.4dB 1W/1m | 89.6dB 1W/1m Bl: 9.3 N/A | 14.1 N/A Xmax: 21mm Rms: 800W Sealed box: N/A cuft Ported box: 6-10 cuft @ 33Hz Sub OD: 18.500” Cut ID: 16.750” Mounting depth: 9.500” Displacement: 0.22cuft Product code: 01918 Price: $ 239.00 *shipping is included Power Handling: 800 watts RMS Sensitivity: 89db (2.83 volts) Impedance: 4 Ohm Nominal (SVC) Dimensions Outside Diameter: 46.2cm (18 3/16") Mounting Diameter: 42.4cm (16 11/16") Depth: 24.8cm (9 3/4") Recommended Box Sizes Sealed: 130 litres (4.6 cu. ft.) Ported: 200 litres (7 cu. ft.) 19Hz tuning EBS: 350 litres (12.4 cu. ft.) 15Hz tuning Mach5 audio IXL-18.4 T/S Parameters Fs = 17.7 Hz Re = 3.4 Ohms Qes = 0.39 Qms = 5.59 Qts = 0.37 Mms = 434.3 grams Rms = 8.69 kg/s Cms = 0.184 mm/N VAS = 274.1 litres Sd = 1029.2 cm2 Xmax = 22 mm Cone Diameter = 36.2 cm $210.00 |
#35 |
They all seem not to excel much in sensitivity which I think gives you less margin to play with correction. On the other hand they all have very high powerhandling, which means you can regain the margin by using a larger amplifier.
The DUAL 1 seems like the best choice...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#36 |
What about these Ciare 18" model 18.00NdW1 price** $210.00
weight 6.3 Kg vc size 100mm size 18" Fs 29hz power handling 500W (AES) Bl (Wb/m) 24.85 Vas (M3) 0.29643 Sd(M2) .115209 SPL 1w1m 100.5dB Qms 12.36 Xmax 7mm* Qes 0.32 Frequency 30hz-1khz Qts 0.31 magnetic induction (T) 1.2 |
#37 |
The 18.00ndw1 has a pretty nasty peak between 1 and 2 Khz. This is not a very big problem, but you can't get away with a simple 6db/oct filter....to say the least....
Furthermore they traded excursion for sensitivity, which is not a bad thing given the fact the woofer is BIG. The low resonance frequency comes in very nice. Conclusion: It can work, but it needs a bit more effort.... |
#38 |
Ciare 18.75 NdW seems more suitable....
#39 |
Here is an extreme dipole. I've no experience with ob but will have in the future. Like the bass from ob!
http://www.rauna.com/slides/speakerwalljpg.html |
#40 |
It looks like the designer frequently kills mosquitos with a bazooka
By the way with the way they're place they're hardly OB, they rather use the corners of the room as enclosure...
| Format and Audio Ripping Discussion Split From Blowtorch Thread | john curl | Digital Source | 109 | 1st August 2008 04:56 PM |
| BSC discussion - split from Usher two way thread | ch83575 | Multi-Way | 32 | 9th February 2007 11:38 PM |
| Page generated in 0.15501 seconds (100.00% PHP - 0% MySQL) with 10 queries |
