I was repairing a pair of 70s three ways today. I had the woofers out running full range on the floor to identify why exactly one of them was distorting massively despite it not rubbing at all. I propped the working one up vertically and was surprised at the sudden amount of bass coming from a 10" speaker with absolutely no baffle or bass boost whatsoever! It didn't go particularly deep but it was definately there and very listenable. As usual with OB bass it was tight and musical. I don't know the Qts or Fs of these drivers but they seemed to work well. Another interesting thing I noted was that there wasn't a bass null at the edges of the driver.
I don't know why these drivers in free air without baffles made so much bass, but I can't wait to try this with some 18" woofers (with a baffle though) OB speakers are really great and I think they are a great way for a newbie to make something great sounding! Why is it that theory predicts depressing bass response from OB speakers and yet many people seem to experience the opposite? |
#2 | ||
some points: what you might percieve as bass might be actualy lower midrange use 30-50 Hz sine wave and compare OB and closed box and you will be cured the amount of bass might be there when you are holding the woofer onfront your head try to hang in the ear and go couple of meter away and you will notice lack of bass the other thing is try to overload them and you will see how little they can handle if no box is behind to work against nothing against OB, been there done that, but once you pass the first infetuation, you will realize its best used for midrange its hard to do right for real bass |
#3 |
can you feel midrange?
#4 |
you can feel anything if you are sensitive enough
lower bass is 20-80 Hz upper bass 80-300 Hz lower midrange 300- 800 Hz (approximately, depends on which book you use as source) if you can feel lower midrange? most definitely! ask a drummer! use sine wave generator and see for yourself have fun |
#5 |
I am a drummer
#6 | |
I understand that Martin King and JohnK both have programs useful to this. Bottom line, you are not crazy, the world is not a simple place. HTH Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well) Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus |
| Teledyne AR-9 plus bonus surprise | KT | Multi-Way | 2 | 16th December 2010 01:49 PM |
| an interesting surprise ( Bose related) | Scioneer | Full Range | 0 | 8th August 2007 11:59 PM |
| a Chinese Diyer,make me surprise... | X.G. | Multi-Way | 56 | 3rd October 2006 05:34 AM |
| Newest IR mosfets surprise again! | IVX | Class D | 2 | 18th June 2005 03:05 PM |
| Page generated in 0.08850 seconds (76.42% PHP - 23.58% MySQL) with 10 queries |
