2 pieces of Data are given.
Look at the frequency and phase responses of this speakers? The 1st photo is Response curve is an average of five measurements: on-axis, 15 degrees left and right off-axis, 15 degrees up and down off-axis The 2nd photo is Vertical axis: phase Horizontal axis: frequency Guess how much this speaker's retail price? |
#2 |
the freq response curve below.
#3 |
it has the classic BBC dip centered around 3kHz and a midbass hump. should sound quite good subjectively. i like this response curve.
#4 |
$2998 inc GST ???
#5 |
Looks like a 3-way with nicely chosen xo points...... er, A$3999 incl GST.
#6 |
99 bux?
#7 |
Awful phase response.
Frank |
#8 |
This "BBC dip" could also be some unintentional response error caused by the mid-high x-over. The hump in the bass response could be from a Wilson or Sonus Faber. I guess the measurements are from an expensive speaker unfortunately.
Edit: The phase-response is either quite good or measured wrong. If it is measured correctly then this is a "real" broadband driver (going quite low however) or some transient-improved crossover design (low order x-over, subtractive etc). This would also explain the mid-high dip. Regards Charles |
#9 |
I'm guessing the xover points are ~150Hz and ~3500Hz? I'm having trouble interpreting the phase response. The 3500Hz dip seems to be indicative of the mid/tweeter being out of phase at the crossover point? Otherwise the phase response graph by seems pretty good ( fairly flat?). I'd be curious to hear others opinions.
#10 |
Hi, $20K,
| FS : pair of Eminence Delta 10" ***LOWERED PRICE*** | punk | Swap Meet | 1 | 12th July 2006 03:08 AM |
| price/performance speaker cables | uzziah | Multi-Way | 10 | 8th March 2005 08:36 PM |
| pair of B&W 602.5 speaker for sale | up4 | Swap Meet | 0 | 3rd November 2003 12:18 AM |
| FS: Pair of speaker cabinets | jbateman | Swap Meet | 1 | 9th August 2003 04:42 PM |
| Page generated in 0.09361 seconds (78.91% PHP - 21.09% MySQL) with 11 queries |
