Hi all. I have been frustrated getting consistent results using a rat shack SPL meter. I have tracked the problem down to the photographic tripod I've been using. Depends on how far the legs are retracted, how high the centre post is raised etc.
Before I build a non resonant stand, I am open ears for suggestions. Thanks in advance. Geoff. |
#2 |
I wonder if the angled legs are causing the reflections. I'd be going for a straight, thin round pole with a heavy round base. Maybe even wrap the pole in a felt or simlar fabric. You could try wrapping your current setup in a soft thick fabric and see if that helps also. An isolation mount made from elastic might also be worth trying on the meter to decouple it from the stand.
#3 |
Proud Union Member
When we measure a room/system with Meyer's SIM3, we just use the standard K&M 201. It more often is any object near the stand that causes problems with reflections. But of course, you can see them on SIM.
#4 |
Thanks guys.
Sounds like a monopole is the way to go. 3 legs of aluminium tube is not exactly anti-resonant. It helps if I grasp the centre pole, but then I'm in the way, and still have to reach the mouse, and I haven't calibrated the grip. The rubber decoupling sounds like a good idea. Works on tone arms. Some mass between it and the meter or mic may help. I'm on a concrete slab, so at least I don't have to worry about floor vibrations. Regards, Geoff |
#5 |
I got a mic stand at the music store, a Euroboom, I think. It was cheap. Three small legs at the bottom, a vertical post, and an adjustable horizontal boom. I use it for supporting all kinds of things (like photo lights), but it makes a pretty good mic stand as well.
#6 |
Old photographer's trick with cheap tripods:
hang a weight (usually the camera bag) from the bottom of the tripod to pre-load the legs. kick the feet outward slightly. adjust the height with the legs, use the largest sections first. Winding the column up is a last resort. is your floor wood or concrete? You're in big trouble if it's wood. Isolation mount would be a good idea. Edit: How about the low tech solution: get a friend to sit in a chair and hold it out at arm's length? or if your hands shake too much, stick it to a hat somehow. Make sure you send pictures. |
| HT stands for??? | jarthel | Tubes / Valves | 21 | 11th August 2006 10:17 AM |
| Speaker Stands? | AJ Bertelson | Multi-Way | 5 | 22nd May 2004 03:57 AM |
| M51 Mic stands | Doug | Everything Else | 4 | 4th July 2003 11:36 AM |
| Page generated in 0.10552 seconds (73.43% PHP - 26.57% MySQL) with 10 queries |
