Old 28th April 2007, 06:30 AM   #1
blue934 is offline blue934  Canada
Default woofer replacement
what exactly are the factors to look for in a driver when looking for a replacement if the original is unavailable?
Old 28th April 2007, 06:18 PM   #2
sdclc126's Avatar
Ideally it should be as close to the original as possible, in terms of sensitivity, resistance, frequency response, power handling, T/S parameters, etc.
Can you find out any of these things for your original driver? That will be a start. What speaker do you have?
Soft Dome
Old 28th April 2007, 06:32 PM   #3
FastEddy's Avatar
" ... sensitivity, resistance, frequency response, power handling, T/S parameters, etc. ..."
Add to this: physical size and mount pattern of course. You might consider the ultimate purpose and expected longevity. I replaced the old Cerwin Vega (sic) in an old BSR box with a boomer normally installed in boom box automotive, primarily because it fit, it could handle the 150 watt steam from the nieces and nephews (played loud) and was a close match to the box resonance ... cost about US$100, shipped/delivered. (http://justwoofers.com = a Pyle Driver Sub wth the ruggedized cone.) Sounds real good and is a good match to the mains when driven w/ active crossover in the sub amp. At my age (lower listening levels), this will probably be in my estate without any deterioration in quality over time.
Old 28th April 2007, 08:42 PM   #4
tinitus is online now tinitus  Europe
You probably wont find a driver with the exact specs to match - anyhow, if its an older speaker it might not matter and you might even be in luck and do better
There could be other considerations such as materials and type of driver
But ofcourse it will have to have the specs needed fore the size of the box, and preferably a nice and smooth FR without peaks - I expect the xo to be rather simple and not exactly perfect either
But to give a better answer it would be nice to know more about the speaker
Old 29th April 2007, 03:52 AM   #5
thanks guys. i would like to build a copy of a kit that i built about 15 yrs ago. i will have to see if i can dig up any of the specs on the original drivers.
ESS amt 1b replacement woofer and PR AudioGeek Planars & Exotics 1 7th November 2008 04:02 PM
Woofer replacement glen65 Multi-Way 0 28th October 2007 03:18 AM
AR TSW610 replacement woofer/mid mista2 Multi-Way 0 16th June 2005 07:33 PM
replacement woofer koski Multi-Way 4 19th January 2004 03:55 PM
Replacement Woofer DavePobuda Multi-Way 0 4th September 2003 09:02 PM
Page generated in 0.07871 seconds (72.51% PHP - 27.49% MySQL) with 10 queries
