When the cone isn't black but you REALLY want it to be
Old 27th April 2007, 04:29 AM   #1
jonkun227 is offline jonkun227  United States
jonkun227's Avatar
Default When the cone isn't black but you REALLY want it to be
I've usually dealt with drivers behind a mesh of some sort. Now I'm doing an enclosure where the cones are exposed and I want a really rich black finish, but without doing anything negative to the sound. I have access to a wide range of inks, dyes, paints, etc. Can anyone enlighten me as to how to make a charcoal or purplish cone black and maybe even a little bit shiny? (The shine is less important but nice.)
Or would I do best to leave it alone? I have searched far and wide for an existing topic about this, but only came up with "how to paint your enclosure" type discussions.
Latex?
Water-based dye?
Sharpie?
Mascara?
Crayon?
Thanks!
- Jon
Old 27th April 2007, 04:32 AM   #2
5th element is offline 5th element  United Kingdom
5th element's Avatar
Im not sure how to do this, but I can guess knowing the cone material is important. Painting plastic, metal, paper etc would probably require different inks.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 27th April 2007, 04:49 AM   #3
jonkun227's Avatar
You're absolutely right. I thought I had mentioned that these are paper, but re-reading my post I see that I didn't.
These are paper. The woofers are neutral but not quite black, and the mids are similarly not dark but also slightly purple. (For those familiar with the Pantone system they are roughly PMS Black 7m and PMS Black 5m. I'd rather see PMS Black 6c.)
If the weight and material didn't make a difference I'd go with a strongly tinted metallic, like PMS 8201, but I'm quite certain that an ink heavy enough to do that would have a serious impact on performance.
I'm thinking a lightweight water-based dye would work best because it would add the least weight to the paper. But it's also the most likely to be absorbed deep into the fibers, reducing the opacity and saturation, defeating the purpose of the exercise.
Seems like anything thick enough to stay on the surface (pigment based) would add too much weight.
Has anyone tried this? Should I get some cheap drivers at the thrift store and practice?
- Jon
Old 27th April 2007, 04:53 AM   #4
terry j is offline terry j  Australia
try asking BudP in the Enable and Mamboni thread, he coats paper cones etc and you may be able to add a colouring agent to it. Who knows, it may even sound better????
Old 27th April 2007, 04:53 AM   #5
jonkun227's Avatar
My wife and I frequently reference Ruby in our day-to-day lives. "Aah! What's wrong with you?"
- Jon
Old 27th April 2007, 04:55 AM   #6
jonkun227's Avatar
That thread seemed to be the closest thing I could find to an answer, but I gave up after the first page or two because it seemed to be only for very precise lettering of the cones. I'll definitely ask him. Thanks!
- Jon
Old 27th April 2007, 05:04 AM   #7
Rounder is offline Rounder  Canada
http://www.partsexpress.com/pe/showd...number=340-512
If this link doesnt work then look up wet look pint black at partsexpress. Not sure how itll look but you can ask around. Says its for paper cones.
The bitterness of poor quality is remembered long after the sweetness of low prices is forgotten.
Old 27th April 2007, 05:10 AM   #8
jonkun227's Avatar
How funny. I had specifically gone to Parts Express and searched for paint, dye, etc., but didn't find anything. Those terms aren't in the title or description. No wonder I didn't find it. I knew somebody had to have encountered this issue before me.
Thanks!
- Jon
Old 27th April 2007, 05:20 PM   #9
- Jon
Haha, good to hear I am not the only one who does it, of course I go for a full out impersonation, I do a rather good Zorg too heh.
When the cone isn't black but you REALLY want it to beHide this!Advertise here!
Cone weight vs Cone stiffness musgofasa Full Range 9 25th July 2008 08:16 PM
best cone profile for sub ? ejaouen Subwoofers 12 17th June 2008 04:28 AM
Too much pressue on cone? K-amps Multi-Way 4 26th July 2007 01:44 AM
Copyright ©1999-2017 diyAudio
