I am about to try out open baffle speakers for the first time (other than my Maggies). I have both a pair of fostex fe207e and a pair of eminence alpha 15.
My plan is to use a baffle about 600mm x 1000mm, sloping backwards slightly with 200-300mm side cheeks. I am keen to keep things very simple initially, with a single inductor on the bass driver and the fostex running full range. I've played around with The Edge software but would appreciate some advice. What inductor value would you recommend for starters? I have read about similar systems using from 3.9mH to 7mH. Does the baffle size seem appropriate? I don't want to get bogged down with BSC filter etc. as my next purchase will probably be a DEQ2496. Any advice would be appreciated. |
#2 |
Martin King has developed a Mathcad program which allows you to determine baffle width and high required and also the roll-off frequency for the bass end.
Contact him, he is most helpful. |
#3 |
Many thanks ttan98 - I've ordered a mathcad model from Martin.
#4 | |
Hi. I've had a lot of experience with Eminence Alpha's in OB situ's. I feel your choice is a good one. You may have to go to a 2nd order filter for the Emmy tho or else you might not be able to make it "shut up". A frequency of about 500Hz should do it. When you go to the DCX, using the same frequency, shut it off at 24dB/Octave or steeper and put a bottom limit on it of around 40Hz with a 2nd order roll. You can also tame the top end of the Fozzie with a 6dB slope at around 8K. Look forward to your results. Ricky. |
#5 |
#6 |
"I'm glad I can build my own mistakes." |
#7 |
I have found my Fostex Fe207E somewhat flat in the extreme high end.
I may be doing something wrong for that result though, they only have about 50 hours on them. |
#8 |
Those are beautiful felixx.
How do you cross them over? Did you use a BSC or equalization? I think my first pair will look a bit less impressive than yours :-) |
#9 |
I use Alpha15A for woofers and works very well.
The cross is active only for Alpha's. The cuttoff is 250hz with Burr Brown OPA2134. I have an active filter "a la Linkwitz" 3db and could be modified easy. The Supravox is free of any components and it goes superb(xmax. is 4mm). Here is an impressive work with Fostex into open baffle: http://www.bd-design.nl/ Quasar.
#10 |
Note that open baffles do not have BSC (baffle step) as such, they have baffle roll-off at 6dB/octave. You can use 2 bass units in a 0.5 way configuration to compensate for 6dB of this roll-off, i.e. extend one octave. /sreten.Active EQ and bi-amping you can do anything with the lower unit. You can reduce the Fostex amplifiers input capacitor to cut low bass. |
| 3 way open baffle with Eminence and Skytronic | SimontY | Multi-Way | 452 | 16th September 2011 10:25 PM |
| newbie eminence open baffle | mrthieme | Multi-Way | 13 | 6th September 2009 06:26 PM |
| Open Baffle Desktop - Fostex 4 | angeloitacare | Multi-Way | 2 | 8th June 2009 11:49 AM |
| Eminence or P.Audio ? Open Baffle or Sealed | Predator864 | Multi-Way | 0 | 23rd January 2009 12:51 PM |
| Eminence Kappalite 3015 as open baffle bass? | EC8010 | Multi-Way | 4 | 29th June 2007 09:05 AM |
| Page generated in 0.10243 seconds (86.27% PHP - 13.73% MySQL) with 11 queries |
