Old 23rd April 2007, 09:09 PM   #1
Default shallow enclosures (on-wall)
I have tried to search for this topic, and found only some scattered information.
Does anyone know of design considerations and techniques for shallow enclosures (about 6 inches deep) intended for "on-wall" installation?
In rooms with limited space, placing the speakers a few feet out from the wall is difficult. For HT, the on-wall placement may be desirable. check out the Morel Vario for a commercial product.
I know that baffle step correction (BSC) often integrated into the crossover would be different.
Another issue is the resonance between the cone and the back wall of the enclosure. The enclosure back would be a node, the cone itself would be an antinode. I suppose some sort of absorption of diffusion directly behind the speaker would help, but what form might this take?
Another issue is the front panel diffraction. The front panel dimensions may be quite a bit bigger than those that would be used with a deeper enclosure, in order to achieve the desired enclosure volume. I suppose that beveled or rounded edges would be helpful. I also see absorptive material on the front panel sometimes, especially around tweeters. What considerations might there be for this issue?
Finally, looking at overall sound quality, does an on-wall system have any inherent disadvantages compared to boxes placed at some distance from the room walls?
Tom
Old 23rd April 2007, 09:25 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Here is a simulation showing what happens for different positioning of the loudspeakers. On-wall speakers typically have a dip in the response (in this case at 300 Hz). The dip is very hard to compensate for. One common way to reduce the problem is to make the baffle non-parallel to the wall.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 23rd April 2007, 10:02 PM   #3
holdent is offline holdent  Canada
Zaph developed a wall mounted speaker and documented the process. It might help. Go to http://www.zaphaudio.com/ and look at "Slimline Wall-Mounted Speaker" Parts 1 & 2. Part 2 explains the design.
Old 24th April 2007, 12:35 AM   #4
David Gatti's Avatar
I've been thinking about the same issue Tom.
My current thought is to have wide tapered edges (maybe 6 inches) from the front baffle to the wall, making a smooth transition and thus hopefully reducing the diffraction. In a wide enlosure you could have an internal V section of wood behind the midrange to deflect the rear wave sideways. Another option could be to have a large opening behind the midrange and the entire enclosure resting on a 1" layer of felt.
Old 24th April 2007, 07:01 PM   #5
Default thanks
Thanks David, Holdent, and Svante.
Zaph has a great example. I suppose that the angle of his boxes helps to make the frequency response dip inaudible. In my case, I'm wondering if I can surround the speaker with damping using a specially-constructed channel around the edge (as deep and as wide as the box thickness?) filled with absorbing material, that is open to the front.
If anyone has any more links to relevant information, please post.
Tom
Old 24th April 2007, 07:41 PM   #6
Svante's Avatar
Default Re: thanks
Tom
Hmm, I am not perfectly sure about this, but a knowledgeble person I know told me a while ago about a similar experiment. It did not involve a back wall, but it was about diffraction. If the sides of a box is covered with absorbing material, it actually makes the baffle step stronger. Not much, but a little.
It makes sense actually, once you think of it, the diffraction comes from the baffle support disappearing at the baffle edge. Absorbing the sound that goes around the corner also removes the support of the side wall.
On the other hand, when there is a back wall involved... I don't know.
From experimenting in Basta! i have found that if the distance from the driver to the baffle edges varies considerably more than the box depth, the dip can be reduced a lot. Unfortunately, this leads to a box that is some 80 cm wide if it is 10 cm deep. This is not very beautiful...
I think the way to go is to put the baffle at an angle.
Old 24th April 2007, 09:04 PM   #7
Surround speakers may give you some ideas, for example this Focal:
Old 24th April 2007, 09:14 PM   #8
Did it Himself
richie00boy's Avatar
Keeping an eye on this thread as I'd like to make some wall mounted speakers.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 25th April 2007, 12:49 AM   #9
soongsc is online now soongsc  Taiwan
soongsc's Avatar
I've spent some time on shallow designs, and still trying to figure things out. But it seems that absorbing material on the wall between the speakers help create better focus. Idealy it's better to start with the absorbing material from the edge of the driver inward. The wall itself needs to be a solid wall that does not have a hollow sound when you knock on it.
Hear the real thing!
Old 25th April 2007, 01:34 AM   #10
FastEddy's Avatar
Of interest on this wall mount subject: http://www.magnepan.com/model_MMGW . I just obtained a pair and the mounting instructions suggest mounting on the wall about head high. The mount kit includes a set of hinges to accomplish this. When not listening, the planar speakers mount flat (about 2" thick). For the best listening the speakers should be angled out from the wall about 30 degrees. They don't have nearly the full range response when flat against the wall (probably having a similar curve to the above as per Svante), but they do sound very nice indeed when angled out. The Magnepan factory does have a tech support line and they apparently can supply pictures, diagrams, response curves, etc. if needed.
I also have a set of the Magnepan MMGs (maggies), and will shortly mount these on the wall in a similar fashion, aiming for some improvements as otherwise, these have to be placed far from any wall or corner. (When the MMGs are angled close to a wall, they do sound a whole lot better, but the solid wall mounts are supposed to contribute to another level of improvement.) I like both sets and recommend them and they sure could be a space saver when wall mounted. (Both types do need a sub woofer to bring out the whole full sound. MMG-W roll off ~ 155 Htz, MMG roll off ~ 110 Htz)
Designing for on-wall/near-wall speaker placement morbo Multi-Way 4 27th November 2010 04:52 PM
in-wall/on-wall speaker? (axiom w-22 clone?) Scott_fx Multi-Way 0 22nd February 2007 02:08 AM
In-wall vs bookshelf spk flush with wall darascott Multi-Way 3 1st October 2005 03:16 PM
Opinions on wall to wall subwoofer array jmiyake Subwoofers 35 19th July 2003 11:26 PM
adding enclosures to in-wall speakers? mjgraves Multi-Way 2 23rd December 2002 06:25 PM
Page generated in 0.12095 seconds (81.06% PHP - 18.94% MySQL) with 11 queries
