Old 23rd April 2007, 07:02 PM   #1
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Tuning my pipe
Hello, I have been given this by WinLsd Pro as its sugestion for my Audax box
Looks good, but I'd prefer to get down to 40hz at least.Is this right?
I tried to change Tuning Freq to 40 for same size box and the curve didn't look right. What an I doing wrong, please?
Cheers Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 23rd April 2007, 10:09 PM   #2
Did it Himself
richie00boy's Avatar
As Fs is about 61Hz, it's not going to go much lower than that with a flat response.
I suggest your best option is to use a filtered alignment, using an active 2nd-order filter to obtain a flat response. You can look at the QB5 articles on the ESP website, but I suspect you may find the calculations not very intuitive. The other option is a more common Keele 6th-order system.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 24th April 2007, 12:28 AM   #3
No innuendo to see here, folks.
Old 24th April 2007, 08:14 AM   #4
mikee55's Avatar
Default Cheers Richie...
Is this the way to go?
Or maybe I should stick with the first one.
Cheers
Mike.
el pipe-o mantisory Subwoofers 5 2nd February 2009 04:51 PM
El Pipe-O's as Art? Scott Stansbury Pass Labs 2 14th October 2008 06:42 AM
El-Pipe-O (El-Pipe-Mino) ??? JDeV Multi-Way 21 26th October 2005 09:00 AM
El-Pipe-O ??? JDeV Multi-Way 0 6th October 2003 09:30 PM
El Pipe-O Nelson Pass Multi-Way 7 9th January 2003 06:30 AM
Page generated in 0.07571 seconds (71.66% PHP - 28.34% MySQL) with 10 queries
