I have searched the web for information about the special woofer used in the TacT w210 corner loaded woofers - but I can not find any info on this special woofer. It is reportedly a low loss, low mass vifa OEM design - I should have bought a pair when it was still available from TacT.
In order to find a similar replacement driver it would be nice to know the TS parameters of the original woofer. While searching I found a picture of this power-horse here: tact driver Masive magnet system ! Help is much apreciated
#2 |
sorry for the double forum post - I lost connection to the server while posting the first one
I do not have the right to remove the first post - admin could you kindly remove the other empty thread with the same topic?
#3 |
diyAudio Moderator Emeritus
Duplicate thread deleted.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#4 |
thanks
| T/S parameters of philips 8'' woofer | hydrovac | Multi-Way | 4 | 21st August 2005 05:31 PM |
| need the Thiele/Small parameters for Jamo woofer 22392 | Ralphies | Multi-Way | 0 | 12th April 2005 10:58 PM |
| DVC Woofer- Does series vs parallel alter T/S parameters? | treedog | Subwoofers | 11 | 14th January 2005 01:10 AM |
| Need t/s parameters for RS 40-1033 (6.5" woofer) | dmcleod | Multi-Way | 3 | 24th June 2004 03:08 AM |
| how do i find thiel small parameters for the radio shack 40-1035 15" woofer | zuki | Multi-Way | 7 | 18th February 2004 12:55 PM |
| Page generated in 0.05906 seconds (77.33% PHP - 22.67% MySQL) with 10 queries |
