I have been trying to find a Audax 8" woofer for my Tangent RS2's
specs were FS:25hz QTS .24 VAS 3.35 cf VC 25mm magnet 26oz Impeadence 8 ohm I found a Pioneer B20FU20 FS: 29hz QTS .20 VAS 3.9 VC Magnet 20oz Eff 93db/watt This is the closest driver I found, I woudl replace both. Any ideas how bad a trade off this is and what might happen? Thanks Bob
RN |
#2 |
Bob,
I would buy your Audax woofer if you decide to replace it with the Pioneer drivers. David |
#3 | |
frugal-phile(tm)
The RS2 midbass is the same as the RS6 midbass, The RS6 woofer is different. The midbasses were off-the-shelf Audax diy units (the woofers tweaked a bit). I sold lotsa Tangents & the Audax midbasses so they are out there. Tweeter failure is most common, so woofers should be out there. Another option would be to sell the good drivers on eBay (good T27s will fetch a fair bit) and retrofit the RS2 boxes. With the removable front baffle, it is pretty easy. For instance a Fostex FE167 BR would go. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Hmmm....... Taking a very large gamble they would suitable, not a good idea IMO. As p10 says sourcing replacement drivers is your best bet, but finding them is the main problem. I believe you need the large magnet version of the two versions of the Audax bextrene 8" commonly used. Or as also suggested by p10 retro fit something else into the cabinets. The main issue with bextrene cone drivers is that they usually have a large midrange peak corrected by the crossover, this can be checked by sketching out the c/o topology. Another option is to contact Wilmslow Audio in the UK and see if they have a recommended replacement, they claim to be "experts" on the subject, and certainly sold quite a few of the wanted drivers when they were sold as kit drivers by Audax. Personally I'd do a bit of research on really good older 2-ways and find a tatty pair cheap and retro fit the drivers +c/o into the RS2's. I'm assuming here the RS2's are the largish stand mounting reflex. (may have got my models mixed up, but that model had T27's) |
#5 | |
frugal-phile(tm)
dave
#6 | |
frugal-phile(tm)
The XOs were made by Falcon or Badger AFAIK... i thot i had an RS4 or RS6 XO-map but all i can find is a picture of the TM3 XO (same box as RS2, but with KEF B200) dave
#7 | |
It was common at the time, for Audax and Peerless to name 2, to make 2 versions of esentailly the same driver with different magnet sizes, the smaller magnet version going into commercial sealed boxes and the larger magnet version generally going into larger vented boxes. If I remember correctly the smaller versions had a J suffix, larger H. |
#8 |
#9 | |
frugal-phile(tm)
They all had H in them IIRC... H2 = 2 layer VC, H4, 4 layers dave
| ESS amt 1b replacement woofer and PR | AudioGeek | Planars & Exotics | 1 | 7th November 2008 04:02 PM |
| Woofer replacement | glen65 | Multi-Way | 0 | 28th October 2007 03:18 AM |
| woofer replacement | blue934 | Multi-Way | 4 | 29th April 2007 03:52 AM |
| replacement woofer | koski | Multi-Way | 4 | 19th January 2004 03:55 PM |
| Replacement Woofer | DavePobuda | Multi-Way | 0 | 4th September 2003 09:02 PM |
| Page generated in 0.10488 seconds (79.70% PHP - 20.30% MySQL) with 11 queries |
