diyAudio Moderator Emeritus
I'm running out of time to complete a birthday present, so my research time is limited...
I'm after an active eq design that contains two notch filters. One is for a broad peak, and the other a narrow peak for use with the FR125S drivers. Eq filters will be in same enclosure as power amp: Source with vol. control -> [active eq -> power amp] -> FR125S fullrange drivers I know next to nothing about active ciruits, but so far I figure a buffer stage followed by two notches. The notch filter calcs on LR's site have me scratching my head V
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#2 |
Don't worry V, it's a doddle...
Look at the first of the three circuits shown on LR's page: the 5.11K resistor forms a potential divider with the R-C-L. The problem is that the 2.5H inductor shown is going to be a well-wound monster! The second two circuits on LR's page show the same circuit but the L is replaced with an op-amp based active inductor (the R appears to vary but additional series-R is present in the gyrator which brings it back to 1.5Kohms). So, start by determining the centre frequency of the notch, shown as fo in the diagram, by inspecting the peak in your frequency response plot. Next, determine the required Q of the notch, again by looking at your peak: Q = (notch centre frequency, fo) / (width of notch 3dB down from the peak, shown as delta f). Referring to the pseudo-schematic in the top left corner of SL’s main pic, select a value for R1. Convert your frequency peak from dB into real numbers (ie 6dB = 0.5, 12dB=0.25, etc) and calculate the depth of the notch from R3/(R3+R1) to correspond. You can now calculate L and C as shown in the bottom right hand corner of SL’s main pic. To replace L with an active inductor, click on INDUCTR1.GIF or INDUCTR2.GIF and use the formula shown for calculating L (I've used the first circuit with good success). The pics also allow you to calculate Rs, the effective series resistance, which you subtract from the R in the R-L-C. The notch filter should really be followed by a buffer to guarantee that the load (R2) does not affect the circuit operation. I'm tired and drunk so errors and omissions can only be expected! I hope this helps, David. |
#3 |
Rane PE 17? Maybe not good enough in the sound department, but as I can pick up one for me for about $200Aus (which is probably less than a 2.5H inductor) it's going to do for my subwoofer PEQ. And, you'd need 2 of them...
You may need something a bit better (or should I say, less) sounding for the FR125...
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#4 | |
I've attached a spreadsheet following your comments. It's for a 6.5kHz peak with Q of 6.5 that needs 6db notch. Does it look roughly correct? Rename file to .xls Edit: Also, am I correct in thinking that a single package quad opamp is all that's needed for the two buffers and two notch/gyrator circuits per driver? V
#5 | |
Ohhh, my head...
My drunken ramblings must have confused you slightly as an error has crept into your calculations: the active inductor you've calculated is for 81.3mH whereas it should be 813mH. Other than that, I agree with: R1 = 5110R R3 = 5100R C = 737pF L = 0.813H ... and using standard values for the active inductor, I get: C = 1uF R1 = 1K R2 = 810R so R3 reduces to 3.3K I'll do a simulation of the circuit when I get home just to triple check. Another useful check is to verify the circuit (when it's built) using Speaker Workshop. Connect the soundcard output to the filter input and the filter output to the soundcard input and set the levels low. Simply click Resource/New/Driver then Measure/Frequency Resp/Nearfield and the frequency response of the filter is shown on the screen. Marvellous! Quote:
Nice one, David. |
#6 |
Thanks David.
My mis-calculation of L was a result of not paying attention to the zeros after the decimal point. Your explanation was perfect! Can I adjust R1, R2 and C in the active inductor to any ratio I like (based on what's available in my parts bin), or is there some method to this? I would think that keeping C low so that I can use a poly cap would be good, but that's about it. How should R1 in the notch be calculated? Finally, can you recommend any free and simple to use software for trying out these circuits. I've used ARTA in the past to verify an active circuit (the ASP for the Orions). It's even better than SW Hope the hangover has subsided ![]() V
#7 | |
Sorry to barge in, like this. But maybe I have some helpful information, for you, if you run some form of Windows: I have used the free FilterPro software, downloadable from http://www.ti.com , and think it might be pretty good for more-or-less automatically designing an opamp-based filter for what you are wanting to do. It supports quite a few filter topologies that you can select from, and draws a schematic of each circuit it designs per your specs, and also plots the amplitude and phase response of the resulting filter circuit. And the free LTSpice software, downloadable from http://ltspice.linear.com/software/swcadiii.exe , is an excellent and extremely easy-to-use circuit simulator, and could be very useful if more details of the filter circuit's operation, or the results of tweaks, or of using different components' models, are desired. If you need more Spice models, take a look at: http://homepages.which.net/~paul.hil...odelIndex.html While I'm at it: There is also a truly-great support/discussion group, specifically for LTSPice, at http://tech.groups.yahoo.com/group/LTspice Good luck. - Tom Gootee http://www.fullnet.com/~tomg/index.html - |
#8 |
Thanks Tom, I have d/l LTSpice and will have a play with it...
Nice info on your website btw.
#9 | |||
Hi Vikash,
I pick a value R1 and use that as a basis to calculate the rest of the components. You have a lot of freedom when selecting R1 and R3 but I'd stay away from anything too high (greater than 100K, say). Quote:
I've also simulated the circuit but it's not 100% correct: the center frequency is spot on at 6.5KHz, the notch depth is exactly 6dB but the Q seems to be a little lower than it should (delta f is 1.4KHz), and I'm at a loss to explain why... The result is exactly the same whether I use the active inductor or passive. I used Multisim so please report back with the results of your simulation and we can compare notes! So when do we get to see to photos of this new creation? Nice one, David. |
#10 |
I don't know if this could be related, but I seem to recall problems using standard notch calculations when I did a passive version too. They didn't hit the spot in simulation as the calcs implied.
I'll report back once I've got a LTSpice model going... V
| Notch filter for Zaph's B3S design | 454Casull | Multi-Way | 1 | 6th May 2009 01:08 AM |
| Notch Filter Design | ChocoHolic | Subwoofers | 36 | 13th October 2007 04:25 PM |
| Zaph's L18 design, notch filter---Do I miss something? | Jay_WJ | Multi-Way | 21 | 11th April 2007 04:30 PM |
| Noise out of active notch filter | reins | Multi-Way | 0 | 6th July 2006 07:34 PM |
| Active notch filter | 5th element | Solid State | 7 | 6th February 2004 10:06 PM |
| Page generated in 0.13807 seconds (82.45% PHP - 17.55% MySQL) with 11 queries |
