I have not seen these published so thought I should share them. Zaph has some of the larger ScanSpeak revelator sliced paper cones but not this smaller 4" midrange. I will leave it to the viewer to interpret the results. It was referenced to 90dB/1m@1KHz. Two samples were tested and both were extremely similar so there is good matching between the drivers.
#2 |
Zaph did tests of the 12M as well. Check again.
#3 |
Ahh yes so he has. It is a pretty new addition - 4th Feb 07. I had not looked since before then. Still it is nice to see his results match mine quite closely.
#4 |
#5 |
Yeah, the ATC has VERY impressive disto specs. Not bad CSD either. But it is more expensive isn't it? Also it simply isn't suitable for the project I have in store.
#6 |
I also took some measurements of the Hi-Vi RT1.3 isoplanar ribbon tweeter.
Click This is a rather nice tweeter for use above 3.5KHz. It offers very low disto as you can see but it also means you have the choice of a ribbon-like dispersion pattern. Maybe good for a MTM layout? Consider that this tweeter costs about £15 each inc.VAT and we are really talking ![]() Oh yes, the other reason I really like this tweeter is that it has a completely flat impedance. So it will work with text-book crossovers. |
#7 | |
The 12M lacks the copper in the motor of its bigger brothers which explains why its a departure from their good performance. The SS and ATC both only look comfortable to 500hz. So I think their purpose and optimum passband are similar. The SS has more displacement but I think thats somewhat academic given the data. |
#8 |
Doubling the distance decreases SPL by 6dB, does it not?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#9 |
Only in true free field
#10 |
Shin, how can you say that 12M lacks the copper short rings
Looking at impedance on 12M amd 15M, they look very similar to me, hard to tell any differense at all, be it 12M, 15M or even 15W and 18W I use 15W, and as far as I can tell, its not distortion that bugs it - I use a series xo inductor of about 0.3mH with RC and notch, and I have coated the dustcap very lightly with bitumen |
| INCREDIBLE 12" woofer-midrange SE friendly, lowest distortion-2khz...MUST READ!!!! | Spiritzly | Multi-Way | 17 | 29th August 2010 01:05 AM |
| Opamp distortion tests posted | sendler | Solid State | 4 | 27th December 2008 07:00 PM |
| Articles on Inductor Distortion Tests? | PB2 | Multi-Way | 2 | 7th September 2008 03:57 AM |
| New Scan-Speak D3004/660000 Distortion Tests | Joe Rasmussen | Multi-Way | 60 | 3rd December 2007 09:07 PM |
| Page generated in 0.11930 seconds (79.23% PHP - 20.77% MySQL) with 10 queries |
