#2331 | |
Bud |
#2332 | |
When Bud describes how to do the enabl treatment he is very clear. Other users also have been very clear and specific in their description - very little metaphor - see, for instance, Alan Hopes description a couple of posts back. (Yes, he is using similes - even scientists have to use them). They are talking about much greater than just noticeable differences. If I could clear out some of the 20 dB down stuff in my unfortunately updated, outdated and no further updates possible system, I would be a happy fellow. (Design and drivers out of date). No point pounding at Bud, and the rest of us by now are mostly clear what the difference is between you. |
#2333 | |
What I am proposing is EnABL'ing the front mounting plate of the driver not the cone. See attached pic. It follows then that there would be no added mass as the cone itself will not be altered. So if there are any audible and/or measureable changes to FR or anything else it will be resultant from only one variable - the EnABL pattern. |
#2334 | |
frugal-phile(tm)
Bud makes 3 posts that describe the procedure. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#2335 | |
When an LP gets scratched it still makes sense; when CDs crack up they go completely senile and gibber incontinently. - Hugo Williams |
#2337 | |
"Bicycle riding is a sport like rock, paper, scissors is a sport." -Michael Enright
#2338 |
Hi Alex in oz
I'm only a couple of hours away from Canberra, and would be very interested in hearing what you have done with enable. would be fun to meet another diyer anyway. I think the last two pages have suddenly taken a turn for the better, the question (to me) that needs to be addressed is Buds assertion (along with others) that there is indeed some sort of low level detail extraction that seems to be inexplicable. We have gone back and forth tawking theory..which seems a bit pointless unless there is in fact an effect to talk about. Bud and others maintain that there in fact is, (whatever the actual mechanism), all others who are arguing theoretical mechanisms seem to have not yet had a listen. Would not the next step be that the offer of enabled vs un-enabled drivers be taken up and evaluated? Pity we couldn't get them in Australia, so I urge you guys over in Nth America and environs to take advantage of your close proximity and do something along those lines. Alex and I will do something here ha ha ha (says me taking advantage of his initiative!) |
#2339 | |
Diaphragm vibrational modes radiate non-uniformly; that is, first from one area of the diaphragm and then from another. (I suspect this radiation possibly has directional characteristics as well). I think this messes up our imaging. So the less these modes are excited, the more aural spacial and stereo illusion we can manufacture. Any sound the diaphragm material radiates, (distinguishing it from the intended audio signal created by the cone movement), is noise. Lower the SPL of that noise and you will hear more music. A side benefit is that the speaker will have less "characteristic sound". .................................................. ......................... I expect the enabl pattern, which was arrived at empirically by Bud, does, in some cases, actually act like a filter for some range of wavelengths travelling through the diaphragm. And, in some unlucky cases it probably acts as a waveguide for for some range of wavelengths - Bud has mentioned that sometimes when first trying enabl pattern on some speakers they have sounded worse. One more thing, damping is is often mentioned on this thread as the result of added mass so often that it may be missed that just adding mass is not the only damping mechanism. Putting a stiff layer on a less stiff vibrating stratum will damp it, gluing a stiffer layer on with elastic glue will damp it, embedding a dense object surrounded by an elastic medium will damp it, even adding holes may damp it. Doing these things with well thought out patterns is not unexceptional - its often done with architectural, automotive and home appliance structural members and panels, and even, once in a while, audio speaker panels. |
#2340 | |
Cheers, Alex |
