Closed Thread
Old 20th November 2007, 12:26 AM   #1001
Banned
Default Heils
http://hometown.aol.com/batespm/images/heils.jpg
No magic dots
Old 20th November 2007, 12:35 AM   #1002
49 - for the 16th time
c2cthomas's Avatar
Sweet!! How did you magnetize those big blocks of wood??!!
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Old 20th November 2007, 12:45 AM   #1003
Banned
Veneer, mortite, a saw blade and felt,,!
Old 20th November 2007, 12:50 AM   #1004
BudP is offline BudP  United States
BudP's Avatar
Well then, maybe I will be quick enough to be the first post of the new century....
As for EnABLing an AMT, I doubt you would need a pattern for every fold. I think this might make them pretty soggy. I would first put a line of blocks at the joint between the mylar emitter panel and whatever clamps them in place, on the mylar. This being the first place where a lot of reflections will arise. Then treat the rest of the core / mounting mass with a linear pattern for every vertical wall or break over from a local horizontal surface that exceeds 10 degrees or so.
Beyond that, just a set of electron pools and you should be good to go, tune up all done....
Bud
edit, oh well, maybe for the beginning of the third century....
Old 20th November 2007, 01:06 AM   #1005
c2cthomas's Avatar
Hey Magnetar!
I've been reading your thread with great interest and looking to do a smaller version of your OB "Creation". Gonna start off with the AMT's 'cause I have 'em in hand - but want to try Freddie's K-tube tricks the way you did on your project. Still trying to figure out a good midrange unit for that important 300-3kHz range - although BudP's EnABL should help WRT that.
Hi Bud - We are in agreement about the folds in the AMT - don't want to touch 'em - for several reasons. I was simply going to slap a dual row EnABL pattern next to the vertical slot near the diaphragm and another set where the "waveguide"(?) begins curving and another on the outside edge of the assembly. As Chris mentioned earlier - there are a couple of key suspects to look at.
Old 20th November 2007, 04:01 AM   #1006
planet10's Avatar
Originally posted by chrisb
absolutely stunningly gorgeous Sonus Faber Stradivari
Sonus Faber Elipsa.
A VERY beautiful loudspeaker... i am very tempted to take a set of Fonkens in once we get them done (still have not yet had EnABLing the cabs hit the top of the queue) in to see which one wins in the midrange stakes (i have the feeling the guys at the Hounds might be a bit miffed)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th November 2007, 03:56 PM   #1007
stroop is offline stroop  Germany
Hi Folks,
I'm going to try and Enabl my fe108es'
Just a couple of questions.... Dave, did you use dammar or puzzle coat on yours?
I could get dammar but not puzzlecoat.
I did however find a water based gloss varnish from the hobby shop that is used over decoupage. Sounds like puzzlekoat but different brand. It's made in Germany. It's runny but thicker and light, milky and see through. I can easily water it down. It seems to flow very nicely onto a piece of paper. It's used like a varnish and of course dries clear. What do you reckon?!
I also got the caligraphy pen and model acrylic.
Thanks!
Stroop
awe nuts...
Old 20th November 2007, 05:03 PM   #1008
BudP's Avatar
stroop,
You will also need to obtain the Micro Scale Gloss coat material to go over all of the other materials. Look here to see what it is and how to obtain it. This is actually quite important and should not be substituted with another material.
http://www.microscale.com/Merchant2/...roduct_Count=9
Might I suggest that you treat some other speakers before moving on to the 108's? Boom box, auto or computer speakers will provide an easy practice, just to get your skill set up to what will be needed.
Besides, this practice will provide you with amazing sound from places you never expected it.
Bud
Old 20th November 2007, 05:20 PM   #1009
chrisb is offline chrisb  Canada
Originally posted by planet10
Sonus Faber Elipsa.
thanks for the correction - the picture doesn't do it justice
dave
that might be a You-Tube moment, but don't expect a handmade coffee afterwards....
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 20th November 2007, 06:07 PM   #1010
Thanks Bud!
I don't have anything else to practice on!
So I'll just keep practicing with the calligraphy pen on paper until I feel confident.
The stuff I got was from 'Marabu' it is high gloss and water, light resistant and is extremely durable. Sounds really similar.
I'll try it see! I'll thin it down though.
Adrian
awe nuts...
Closed Thread
Page generated in 0.15816 seconds (77.67% PHP - 22.33% MySQL) with 11 queries
