Beyond the Ariel
Beyond the Ariel
Old 25th June 2013, 09:19 AM   #8991
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Originally Posted by Face View Post
It appears Tannoy was way ahead of it's time.
As for Wilson, they appeal to the "appearance" first crowd. Although, they recently started the to transition to soft dome tweeters, and now are much less annoying to listen to.
I think they are just shying away from a problem they cannot solve by moving to soft domes.
Hear the real thing!
Old 3rd July 2013, 03:37 AM   #8992
DougL is offline DougL  United States
Lynn,
I was looking at pictures of the AZURAHORN AH-425, and They appear to terminate at the mouth at between 90 and 120 degrees.
I understand that a Le Cléac’h Horn should have a mouth rollback of about 360 degrees.
What did this compromise entail?
I was looking at the frequency response and impedance plots on this site and it looks like there is some ripple in the 1k and below measurements.
https://sites.google.com/site/driver...ura-425hz-horn
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 3rd July 2013, 12:25 PM   #8993
krzys is offline krzys  Canada
Beyond the Ariel
Default Autotech alternative ?
The Autotech JMLC horns have mouth termination not fare from 180 degrees. I have the 325 and the 1000 horns. The FR is smooter in the mids tha Azura horn. Does anyone considered them as an alternative to the Azuras? Lynn have you looked or tried them ?
Chris
Ps first graph is for Azura 425
Old 3rd July 2013, 07:19 PM   #8994
hum4god is online now hum4god  United States
hum4god's Avatar
Default Radian Beryllium domes
Hi
i talked the other day to a very nice guy at radian who told me that they are ramping up production for the Beryllium domes for their drivers which means that the 745 neo is now available w/ truextent diaphragm from materion through usspeaker .
i was also told that all other CD's will be available w/ the new Be diaphragm .
i will have to try them and see what the fuss about BE is about .
Old 4th July 2013, 05:16 AM   #8995
krzys,
I like the Auto-Tech horns, but I can't find what T value Auto-Tech used.
I was looking at the JMLC-400 as being more equivalent in size to the AH-425.
I would be interested in seeing if others have hands on experience with the Auto-Tech horns.
Doug
Old 4th July 2013, 10:06 AM   #8996
Lynn Olson is offline Lynn Olson  United States
Lynn Olson's Avatar
The DriverVault notch between 3 and 4 kHz is a driver artifact, as far as I can tell. The width and depth of this notch was not the same between the two 288's tested by DriverVault, leading me to surmise that either the centering of the diaphragm, or differences in radiation from the tangential surrounds, is responsible.
The notch is not present with the Radian 745Neo driver, with very smooth response between 700 Hz and 10 kHz. Radians use a stretched Mylar surround instead of the Altec/GPA stamped tangential aluminum surround, as well as a different phase plug. (My understanding is the Radian 745Neo has a more sophisticated phase plug than the 745 ceramic, which gives smoother response in the 1~5 kHz region, as well as a little bit higher efficiency.) The potential downside of a stretched Mylar surround is a higher Fs for the compression driver, which limits the lowest frequency that can be safely used with low distortion.
The question with any LeCleac'h horn is the match between the exit angle of the compression driver, and entrance angle of the horn. These should be as close as possible, and if there's a mismatch, it's better that the exit angle of the compression driver is a bit narrower than the horn entrance.
If compression drivers and horns are mixed-n-matched without attention to exit angle, the response variations might be the result of mismatch, instead of anything the horn is doing. Similarly, it's a good idea to see how much difference there is between different samples of compression drivers ... if there is, that points to potential problems with the diaphragms.
Old 4th July 2013, 12:25 PM   #8997
Beyond the Ariel
Originally Posted by DougL View Post
krzys,
Doug
Dough, I can not find the reference but as I remember T is 0.8. Maybe JZagaja or JMLC can chime in and confirm. They have designed those horns together.
I like those horns very much, they measure and sound very well, much better than my previous Tractrix 400 Stereorlab horns. They are BIG!
Old 4th July 2013, 08:30 PM   #8998
Lynn Olson's Avatar
The entrance angle would be of interest also: zero degree, eight degrees, or what?
I agree about the sonic (and measured) differences between LeCleac'h and Tractrix horns. In addition to lower (nearly absent) horn coloration, the LeCleac'h profile has a very deep "3D" presentation, which they share with the big Altec 1505 and 1005 multicell horns.
Old 5th July 2013, 11:54 AM   #8999
Beyond the Ariel
Lynn, directly from Jzagaja , the entrance angle of the Autotech 1.4" 350 JMLC is 5 degrees (half angle as I understand). Since I use GPA 288 with an angle of 4 degrees, it is very close.
Chris
Old 5th July 2013, 12:20 PM   #9000
jzagaja is offline jzagaja  Poland
Beyond the Ariel
Autotech always use T=0,8 except JMLC-200 which uses T=0. JMLC-200T uses T=0,8 as well. JMLC-350 has half angle of 7 degrees. It's good for tweeter application especially with new Radian 475-Be that we just received.
Visit us at http://www.horns.pl/
The SEOS™ Project http://www.avsforum.com/t/1291022/he...-rallying-here
Beyond the ArielHide this!Advertise here!
Copyright ©1999-2017 diyAudio
