Beyond the Ariel
Beyond the Ariel
Old 28th May 2013, 12:14 PM   #8841
Pano is offline Pano  United States
Pano's Avatar
Beyond the Ariel
Originally Posted by soongsc View Post
This is dividing two ways?
Yes, for a two way. I did look at 3 way, but don't remember what I found (if anything).
Old 28th May 2013, 09:52 PM   #8842
IslandPink is offline IslandPink  United Kingdom
Interesting that dynamics tend to go together with tonal clarity .
I tend to think both are connected with low phase errors or low phase distortion.
This comes from experiences with bass rendition in home-built tube amplifiers, single-driver speakers ( in the midrange ) and some speaker wires I bought recently (!) .
ps. I haven't got any maths to back this up ....
Old 29th May 2013, 12:18 AM   #8843
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Generally, this is where listening tests become confusing, especially when reading a description without being there together. I just went through some tuning of an amplifier. Looking at the rough simulations, mainly the difference was frequency response above 10KHz and the input impedance in that range as well. Now the real funny thing is, I could arrange the components in difference sequence between two points, and the sim would show the same thing because, but the consequences were totally different. In one case, the sound field was mixed up, the low notes of a cello was sort of distorted, in another case, the sound field was more well laid out, and you can feel the correct dynamics and timing associated with the performance.
Hear the real thing!
Old 29th May 2013, 09:27 AM   #8844
Lynn Olson is offline Lynn Olson  United States
Lynn Olson's Avatar
My goodness, take a few days off to enjoy the Real World with family and friends, and the forum goes nuts!
It's been a good discussion though, and I thank Mr. Pimm and other unexpected contributors for their comments. Lots of good postings to think about.
There are things about perception of dynamics in loudspeakers that I find quite mysterious and have no explanation for, not even a likely hypothesis. For example: dynamic tracking in a multiway loudspeaker.
A number of commenters have noticed that perhaps the greatest virtue of horn systems is the way they play quietly ... low levels just sound more natural and true-to-life than low-efficiency loudspeakers. The little bitty microdetails just sound better, for some reason.
A more significant matter is the (subjective) failure of complex multiway loudspeakers to dynamically track at all levels. In other words, if a low-efficiency system is subjectively balanced at an average replay level of 85 dB (pretty common in the high-end biz), it sounds wrong at background-music levels of 50 dB, with dull, slow bass, murky midrange, and scratchy treble. You might think "Fletcher-Munson Effect" until you compare how an efficient loudspeaker sounds at the same 50 dB level ... the murk is all gone, and the more-efficient speaker sounds pretty much the same as it does at higher levels. Why?
This subjective mistracking is annoying enough that many former owners of complex and expensive 3 and 4-way systems have given up and gone the complete opposite direction, single-driver loudspeakers (typically with rear-horn loading).
I know from bitter experience that 3-way speakers are not fun to design, and 4-ways are just about impossible. It's easy enough to make them measure flat, and do the directivity dance that's in fashion now, but subjective integration is a real challenge. The commercially available high-end speakers fail the integration test dismally; what I hear at shows from the $20,000 to $100,000 vendors is disjointed and fatiguing sound.
The real test for an expensive high-end loudspeaker with a zillion drivers and a crossover of unknown complexity is simple: can it play background music at background levels? I'm serious here. Can the $100,000 speaker sound as good as a single-driver table radio at table-radio listening levels? Do you enjoy listening to it, or does it drive you away?
It's surprising how many high-end systems fail the background-music test ... in my experience, most do, with the complex multiway loudspeaker seeming to come completely apart, as if the different drivers are playing different tunes at different times. Play the reviewer-approved $100,000 system at audiophile levels with a 200-watt amplifier, and coherency returns, but turn it down, and the sound comes apart again.
Part of this is listener sensitivity. Like the annoying color-flicker of a slow LCD television, once you get sensitized, it's impossible to ignore. Some listeners give up and embrace the single-driver religion and never look back.
Other folks have noticed that high-efficiency loudspeakers are more consistent at low levels. An entry-level Klipsch speaker that might drive you out of the room at very high levels can sound pretty appealing at low levels, with a surprising dynamic clarity and openness to the sound.
This is all purely subjective talk, and I really don't have much of an idea why this problem of dynamic tracking seems to exist. But I do hear it ... it's the first thing I notice when I go visiting and hear a big, complex, high-dollar system. The desire to leave the room becomes very strong and I find myself making a diplomatic excuse to suddenly go elsewhere. Karna forgoes the diplomacy and just walks out; that's happened at more than one hifi dealer.
This is a big part of the reason I stick with 2-way systems, sometimes with "extensions" for very deep bass (below 50~80 Hz) or treble above 10 kHz. I never really liked the 3-ways I've designed, and the 4-ways were just outright failures. Getting things flat is pretty easy, and directivity control is pretty straightforward these days. If a speaker designed by somebody else is a flop, it doesn't bother me that much ... someone else's problem, not mine. But if it's my speaker that I can't stand to listen to, well, that's a big deal, and a pretty big signal I've gotten something very wrong.
Old 29th May 2013, 12:09 PM   #8845
Pano's Avatar
Beyond the Ariel
Thanks Lynn. Does it still sound good when you turn it down, or does it "come alive"when you turn it up? Two common problems that were demonstrated to me almost 30 years ago in Paris. I still don't understand why, either. But it certainly is a common phenomenon.
Take the Speaker Voltage Test!
Old 29th May 2013, 04:14 PM   #8846
soongsc's Avatar
Something might be wrong with the volume control design for those cases?
Old 29th May 2013, 06:22 PM   #8847
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
Beyond the Ariel
One of the simple questions may be is it the electronics running at extremely low levels that is causing the problem? We all should understand by now that at less than 1/3 power output things become quit difficult for many amplifier designs and I am wondering if this is some of the phenomena that we think we are hearing from the speakers themselves or are we hearing the amplifier distortion and increased noise floor? I am just thinking out loud here, not evidence but thinking what is going on in the rest of the system as we decrease that amplifier output.
Old 29th May 2013, 08:10 PM   #8848
dumptruck is offline dumptruck  United States
That specific explanation doesn't make sense - it would have to be the opposite (sounding better at lower amplifier output). However, even though I've certainly noticed the correlation too, I'm not convinced there really are examples where simple in-room measurements don't explain an efficient speaker sounding better at low volumes than an inefficient one.
Old 29th May 2013, 08:17 PM   #8849
That can happen but it's not enough to explain what's going on in compression drivers, for instance. I run both Lynn's Ariels and the Azura AH425/GPA288H's with similar SE tube amps that are very good at low levels. The compression drivers work better at low listening levels , despite the amps working at VERY low signal levels on those with 109db/w.
I have a suspicion that there are mechanical threshold/hysteresis effects that start to swamp the signals at very low levels of motion in cone speakers, that don't happen with compression drivers where the diaphragm is moving on metal or mylar flexures, with very low hysteresis and 'clean' elasticity .
It does also seem this is supported by speakers with heavy rubber/foam roll-surrounds being more 'dead' at low sound levels than those with pleated/concertina surrounds. the Supravox 285GMF for instance has lovely realistic bass and presence at low signal levels.
Old 29th May 2013, 10:59 PM   #8850
Lynn Olson's Avatar
My own gear is pretty well-behaved in this respect ... but then again, it's all Class A vacuum-tube throughout the signal path, with the number of coupling caps kept to a minimum (two in the Monarchy DAC, and one in the tweeter crossover). I was a bit surprised to find that sigma-delta digital converters tend to sound dull on low-level material, while the better-quality ladder/R2R converters (Philips TDA 1541, Burr-Brown PCM63, 1702, and 1704) have quite noticeably better dynamics.
The drivers in the Ariel don't drop into the murk as readily as more modern audiophile drivers ... different spider and surround, or better magnetic design? The AH425 and Radian 745Neo and Altec/GPA 288 have sterling low-level resolution and tonality, no problems there at all.
Tonality and resolution at low levels was one of the big differences between the JBL 2226 and the GPA 416-Alnico. The JBL sounded flat and dull, while the 416-Alnico had the trademark Alnico sparkle to the sound, and most noticeably at low levels. If you want to hear the difference between magnet materials, and overhung vs underhung voice coils, low-level listening is where it is most apparent. IslandPink, please tell us more about the sound of the Supravox 285GMF, especially how it compares to prosound drivers.
If the sound goes dead at low levels, that's a sign that something's wrong ... it doesn't happen with live acoustic music, where playing quietly has a special beauty all its own. The sound of a harpsichord is a travesty on most high-end audio systems, but is really quite beautiful on a 5~7" full-range speaker, or a high-efficiency system with the right magnet design. In real life, the instrument has an amazing shimmery sound that only rarely makes it through the recording and playback process. I've heard Bosendorfer pianos sound like that, too ... an almost bell-like sonority that almost never comes through on recordings.
I like techno and electronic music as much as anyone ... there certainly was some terrific stuff at the last ETF I attended ... but there are musical instruments have ravishingly beautiful sound when you hear them in person, standing or sitting a few feet away. It takes a very special system to get even an approximation of the beauty of the live performance.
Beyond the ArielHide this!Advertise here!
