#8311 | ||
- Here's the distortion ( & FR ) plot of a poorly fitted ( new GPA ) diaphragm ( belonging to Pano ) put into one of his 291/288 driver bodies . ![]() More ( from Pano ) ; ![]() Notice the simularity to your ; ![]() - I recommend you remeasure the distortion content ( using STEPS, HolmImpluse or REW ) & then look in the 3.7Khz area. - If H3 has climbed as high as H2 in the region , then your diaphragm is poorly fitted . - If that's the case, simply refit/realign it . H2 vs H3 should look something like this ( when the diaphragms are fitted properly ) ; ![]() or this Quote:
<> EarlK |
#8313 |
Pano,
- My plot (5th pic ) has a pretty small dip at 8K ( coinciding with a similar reduction in H2, fwiw ) / leading me to believe it is a mechanical phase cancellation ( of some sort ) . - The (4th) pic with the 8300 hz suckout belongs to Coen , of Why-Do-My-288-8Ks-Sound-Like-Cr@p ? fame, ( sorry I wasn't a bit more clear on that ) . <> EarlK |
#8314 |
Thanks Earl. I'll have to look back at my 288 measurements on a different horn, but I think the dip is always there. You see a little on the Emilar horn, but not nearly what I get. The wavelength is just about the same as the distance from the diaphragm to the exit of the driver throat.
#8315 |
If it's like with the small format drivers, it, and the peaks/dips above it are all due to the discontinuity created by the driver/horn junction causing reflections back to the driver's internal horn throat. I smoothed out/extended the HF response of a pair of 802D/511 combos by replacing the cardboard spacer with a metal one sealed with wax paper gaskets, then align honed the assembly.
The downside of course is that this would have to be redone each time a different horn was used if you wanted to maintain this level of HF performance. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8316 |
Lynn ... can I get some recommendations for resistive slot ports on my new boxes. I see two choices for area, a % of the cone area or use a standard speaker program (Win ISD or UniBox) to get close. Length is the problem with slots as they are harder to adjust than typical round ports. There is also the Onken phenomena with the ports hugging a wall. I noticed the port area on my Jensen Ultraflexs is just about equal to the 12" Sd in the original design and are very short. I'm not sure if Cyr-Marc's Onken spreadsheet would be of much help.
Thanks, Zene |
#8317 |
Hi Lynn, Earl K, Pano and others, thank you for your responses and help. Indeed, I bought two GPA 388 in April 2010. Both measure the same so I thought that it is normal with the aluminum membrane (part number 23763) but I got frustrated when I read that 288 measures flat on Azura horns. I have chosen GPA driver because I read some negative impressions about the SQ of Radian drivers.
My horns are Autotech JMLC 350 made from fibreglass with very smooth throat, 8 deg entrance angle, steel mounting flange and 388 have neoprene soft gasket. I think that I can conclude that neither the horn nor the gaskets are the problem. Searching in the tread I found that we had the same discussion in December 2009, page 646 posts from 7th, post 6452. I then must conclude that GPA drivers are not reliable and could not be recommended (or that the response isn’t flat at all). I cannot accept that a driver paid 340$ need some work and realignment. I will open them and try to align the membranes and will report the result. At GPA site I found this: http://www.greatplainsaudio.com/LgDrvrDiaRepl.pdf The instruction recommends using a spider shim but I don’t have this shim!!!!! Insert the spider shim that was shipped with the new diaphragm/voice coil into the voice coil gap, as shown in Figure 5. Figure 5. Spider Shim Installed Into Voice Coil Gap 10. Carefully place the new diaphragm/voice coil assembly onto the dowel locating pins. DO NOT install the diaphragm hold down screws at this time. The shim sets the voice coil into the precise position necessary for proper sound reproduction, while the free locating pins move to accommodate the slight adjustment needed to properly align the entire assembly. Christophe |
#8318 |
Why not contact Bill and have this discussion with him. Perhaps he would offer other solutions, although you have not posted response to compare to. I have some 288K coming, so I guess we will see about them.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#8319 | |
Chris |
#8320 |
Chistophe, as far as I know, the spider shims come only with new diaphragms so that you can align them when you install them. My 288s were 291s, I added the new diaphragms to them. Alas, mine did not have the locating dowels, so alignment was very tedious, even with the spider shims.
Your 388 drivers should have come aligned.
Take the Speaker Voltage Test! |
