Beyond the Ariel
Beyond the Ariel
Old 8th October 2012, 04:18 PM   #8221
DougL is offline DougL  United States
Lynn,
From your answer, I see I phrased the question badly.
Did you consider a .5" Compression driver / horn as a super tweeter?
As far as I know, only B&C makes one.
It sounds like it would work, but you never know.
If you use an approprate horn profile, it should retain much of the character of the mid-range horn..
Doug
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 8th October 2012, 05:34 PM   #8222
badman is offline badman  United States
badman's Avatar
How much you can push a horn depends a lot on the listener tastes and room- JBL for example specs the 1" exit 2426 to 500Hz in a level-limited app- I've run it just a smidge below 1k on a large 90 degree conical OSWG, and never felt I was asking too much from the phragm.
I agree with the decade rule, however, and never did try to get much above 10k out of it (the response dies there anyway and I needed to preserve sensitivity).
A fella can achieve high sensitivity from the Heil AMT1s by waveguiding it, which actually will do 1k-20k at around 96dB quite nicely, but it's not by any stretch a traditional horn, just a waveguide determining coverage pattern and terminating the device properly instead of with the hard edges. It buys a few dB in the low end of its response, letting you suppress that with the XO and get more SPL per watt and diaphragm displacement.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 12th October 2012, 10:32 PM   #8223
Pano is offline Pano  United States
Pano's Avatar
Beyond the Ariel
Just a brief update:
Thanks for the advice on the Stanton 681, Lynn. I have it running now with a new conical stylus and it seems rather nice. Seems a good fit for the mass of the Grado maple arm. Surface noise is much reduced from the Shure MM cart I had before.
Balance between channels is near perfect - just a small fraction of a decibel difference Left to Right. I checked it on two mono pressings, a Decca from 1949 and an RCA from 1968. Tracking force is now at 2.7g. Might need to adjust that for best tracking - but it's not bad now. Will check with the Shure tracking LP which came with the record collection.
Take the Speaker Voltage Test!
Old 13th October 2012, 01:39 AM   #8224
Zene Gillette is offline Zene Gillette  United States
Hi ... ports are a pain. Lynn says he is using a distributed port which could be close to Onken style if I guess correctly. I see nothing about using larger conventional ports with the exception of box depth limits and frontal area fit considerations. All programs just use a "no-noise" approach for minimum size. Where is some data on larger vent area ports? I would like to use many 2" or 3" dia ports on a 16 cu ft 2x15 box.
Onken, though not conventional, uses up to 85% of Sd and does pretty will as my 1954 Jensen Ultraflex's attest to.
Thanks, Zene
Old 13th October 2012, 02:39 AM   #8225
Pano's Avatar
Beyond the Ariel
Cool. Got pix of the Ultraflex? What's the driver?
Old 13th October 2012, 05:00 AM   #8226
Pano ... pics would be banned by moderator. I never finished, just modified for a 15", braced the hell out of it and threw in a Paudio 150 I had extra so is not a good match. Front full of white filler and no grill. Not something I would want to show. Lacks bass as you might expect but otherwise not bad. As soon as I get a decent bass up and running I will finish and then can display.
Zene
Old 13th October 2012, 03:49 PM   #8227
Nelson Bass is offline Nelson Bass  Denmark
Banned
For your inspiration:
Old 13th October 2012, 03:54 PM   #8228
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Beautiful. What are the drivers and do you have a build thread?
...Shape the sound , Man!
Old 13th October 2012, 04:20 PM   #8229
hum4god is offline hum4god  United States
hum4god's Avatar
this is a bd-design reference compact bass w/ their own bd15 driver .
more information and plans somewhere on the webpage or forum .
BD-Design - Orphean MkII
Old 13th October 2012, 07:05 PM   #8230
Ed LaFontaine is offline Ed LaFontaine  United States
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Timely...I am inspired
Beyond the ArielHide this!Advertise here!
