#8121 | |
Dynamics to the people! |
#8122 | ||
Altec drivers and horns are works of art, the Altec crossovers were just a piece of work. My main objection to them isn't the parts quality, it's the values of those parts. They are mostly just textbook standard - not optimized to the speaker at all. Except maybe the model 19 crossover, everyone seems pretty happy with it. The very first step in getting these to sound good is a proper crossover. And yes, the cabinets rattled and buzzed and the ports were too big - but that is no hard to correct. Time consuming, but not hard. The design of the Altec 825/828 bass cabinet is pretty good, as long as it's built solidly. FWIW, I've seen more recent JBL cinema cabs that were far worse. How did they get away with it? I've heard a lot of music and a lot of speakers in my life, the hotrod A5 still remains my favorite speaker. It's the best all-rounder I've ever heard. Sure, some speakers have more detail, higher highs - lower lows, bigger space, more pinpoint imaging, but none sound more like real musicians playing real instruments in a real space. That's what I want. Your LTO should be very much that type of speaker. I hope it gets built by DIYers around the world and opens up a window into just how much music there is in the recordings we all know.
Take the Speaker Voltage Test! |
#8123 |
Does anybody have complete TS data for the GPA416 16ohm Woofer, and frequency/impedance response they can publice?
I have tryed to contact GPA on mail without any luck. What is the price on this driver? Lynn you describe it has some kind of special edge treatment to reduce peaks in the roll off area, how does that look like, how is it made? |
#8125 |
Thanks Pano, ok, so nothing new under the sun really..... Just good engineering! I am exited to see the TS data, while I feel it is fantastic high sensitivity in 16ohm Lynn is aiming for.
#8126 |
Altec Lansing GPA 416 416-8B Alnico NEW | eBay
You would need to request the 16B. That's actually from GPA (i.e. "direct" sale). Considering the materials alone vs. the marketplace and "similar" items, it's a bargain.
perspective is everything Last edited by ScottG; 23rd September 2012 at 07:15 PM. |
#8127 |
#8128 | |
![]() It's also possible that you might prefer it without the super-tweeter.
perspective is everything |
#8129 |
The Radian 745 Neo is $300. The GPA Alnico 288 is $550. (That's each)
I still think you could do it for about $3000 the pair, with some DIY. Build your own horn and save even more (hint: paper maché) You could hit $2000 for the pair if you're frugal. They won't be the exact LTO, but close. |
#8130 |
Papier mache is a good idea, but of course the problem is the mould. I give full instructions on my website (Azurahorn.com) but in reality it is more work than you would want to go to. An alternative method is to build up concentric discs of 2 ply cardboard (using he Le Cleac'h spreadsheet) and fill the steps.
The profile is not proprietary - anyone who wants to give it a go can enter the input data into the spread sheet and obtain it. T=0.707 425 Hz cut off one side wall angle 4 degrees Throat 1.4" Mouth diameter 420mm Having just returned to the fold after a detour round TD2001s on 340 horns and Lowther PM2A on 204 horns I can say with confidence that the design choices that Lynn took wrt the 425 horn are spot on - hard to describe but you get that immediate feeling of it's just right. martin Last edited by Truetone; 25th September 2012 at 02:10 AM. |
