#7851 |
Forgot to add: the Rhythmic Audio system even corrects for things such as memory distortion. Here is a link to the Rhythmic Audio website:
Rhythmic Audio products page Enjoy, Deon |
#7852 |
Also forgot to add, the RA subs also have toggle-switch adjustments for the steepness of the XO slope (12dB/24dB), a rumble filter, adjustment for low frequency extention (14Hz,20Hz,28Hz), and damping (lo,mid,hi).
Greg, I'm curious to know what was your experience with the adjustments. How easy or how hard, and how different for the different venues and needs (studio vs. home). Thanks, Deon |
#7853 | ||
Woofer measurements Quote:
#7854 | |
I've also heard others claim that the Rythmik stuff is just average or not that good. Well, it's all up to integration, isn't it. If you don't get them adjusted and mated with the speakers very well, of course the resulting outcome might not sound that good. Properly implemented, these subs are excellent. Also of tremendous sound and quality would be Dannys take on open baffle servo subs over at GR Research. He is partnered with Brian at Rythmik on these. I've heard them several times and they are superb and dig really deep. He uses them successfully with his open baffle, high efficiency models with no problem, so in practice, low efficiency open baffle drivers are working just fine with nearly 100db/spl sensitivity speakers. I also have to note that Bob Katz of Chesky Records and masterng fame has heard the subs and is impressed as well. Once he hard the mains, he thought they might be the best large monitors he's ever heard in a studio setting. Now they we added the subs, we are possibly surpassing the sound of his own mastering studio. I used to be an assistant for him many years ago and he is local in town here in Orlando. Greg |
#7855 | |
Hear the real thing! |
#7856 | |
Thanks, Deon |
#7857 |
#7858 | |
An amp like mine with a Susan-Parker Zeus output power stage, also with no global feedback, and with the output transformer wired in 2:1 mode has an output Z of 1 ohm (right in the pocket). With a nominal 16 ohm load, the power output is ~26 Watts, again in the pocket. This speaker is looking good. In 4:1 mode, output is ~7.5 Watts, but the output Z is 0.25 ohms, perhaps too low. However, if only half of the windings are used, then output Z can be 0.5 ohms. Output Z easily can be brought up to the 1~2 range in 4:1 mode by using resistors instead of external links to wire up the 4:1 mode. If 7.5 Watts is enough (it should be), then the 4:1 OPT mode with the external resistor used as a link could be the best match because 4:1 mode measures the cleanest. |
#7859 |
Thanks for the link. Very interesting.
#7860 |
Hi Lynn
are there more details about your resistive-vent enclosure for the Altec/GPA 416B Alnico documented somewhere ? i am also intrigued by the concept but cannot find a lot of information . so if you could shed some more light on that concept , and the results your are getting, that would be much appreciated . regards malcolm |
