#7351 | |
Anyway, it sounds like a promising start. |
#7352 | |
Rob
"I could be arguing in my spare time" |
#7353 | |
Banned
Carry on... |
#7354 |
#7355 |
I like the color scale I choose because it represents the most natural colors for human eye, the electromagnetic spectrum. Anything else is gimmickery. ![]() It's made in nature in rainbows, halos, glories etc. ![]() ![]() - Elias
Home page If our hearing would be accurate, we would be hearing two loudspeakers. |
#7356 |
I don't find mono depth surprising since I experience it conctantly with my dipole line array (in one speaker mono). Depth is perceived if there is enough 'ambiance' in the recording. High speaker directivity allows it to be heared and not be spoiled by the listening room. - Elias
#7357 |
Normally this quality would be associated with good CSD and low distortion. Very good.
Hear the real thing! |
#7358 | |
The measured (not calculated) phase match between the drivers at crossover is 5 degrees or better; the null with the drivers reversed-phased is 25 dB deep, and the slopes of both sides of the null are symmetric. When put in-phase, response is flat through the crossover region, and off-axis response is smooth as well. The data Gary has sent me looks looks good for a system using large-format woofers and compression drivers, and the subjective reports are matching the objective data. Definitely in a different class than an Altec A5, more like a JBL Everest system, but with a simpler crossover. The woofer only needed one modest notch filter, and the horn did not require shelf equalization or a notch filter, rather impressive for a 1.4" format driver. Response ripples predictably start above 8~10 kHz, although they are smaller in magnitude than I expected, probably thanks to the damping of the Mylar diaphragm surround of the Radian 745P. It would be interesting if the TrueExtent beryllium diaphragms were available for the Altec 288 or Radian 745P drivers; this would offer response beyond 15 kHz without a supertweeter. Considering the not-insignificant cost of a beryllium diaphragm, a high-efficiency ribbon supertweeter offers more extended response (beyond 50 kHz for the RAAL) and better horizontal dispersion. Last edited by Lynn Olson; 27th September 2010 at 01:08 AM. |
#7359 | |
Cast bronze looks classy, I have to give it that, and the wood midrange horn is a work of art. Would have been nice if there were some measurements instead all the pictures taken from weird angles. Last edited by Lynn Olson; 27th September 2010 at 01:28 AM. |
#7360 |
Good news on Gary's system, Lynn. Can't wait ot hear more progress reports. Too bad I'm no longer in the neighborhood, I'd pop over to hear it.
I would leave out red altogether as a pure color - probably. But yes, I do like starting with yellow as the highest level because it looks the brightest. Then down into green, aqua, blue and maybe black at the lowest point. The idea is to have what looks brightest to the eye represent the high levels and the dark colors the low levels. Unfortunately that does not follow the visual spectrum - the eye does not work that way. I'll try some color gradients and present them for our amusement. =)
Take the Speaker Voltage Test! |
