#7291 |
Harmonic is a wave thing.
Physics Tutorial: Guitar String Harmonics
Scott |
#7292 |
So, it should show up in frequency domain which does not seem to be the case.
Hear the real thing! |
#7293 |
What we both thought was diffraction turned out to be reflection from a projector box hanging from the ceiling...I moved the mic into a position to "see" the reflection...oops! Pretty sure there is a CSD plot in the thread.
Paul |
#7294 |
So I guess this is another example of the very sensitive wavelet transform showing us something that is so minor that we won't hear it.
Scott |
#7295 | ||
Hear the real thing! Last edited by soongsc; 25th August 2010 at 05:04 PM. |
#7296 |
Lynn
You asked a few days ago about the Onken/Jensen cabinets I'm making . The design is basically the standard design as given on the Supravox site : http://www.supravox.fr/kits/jensen.pdf I looked for a while at alternative alignments but could see the inevitable trade-offs of low-end extension . I'm not intending to add any further bass complexity due to space considerations . I'm hoping it will be an OK trade-off with the nice Supravox 285GMF which have very light cones . The current philosophy will be to drive these bass speakers from a Pass F4 driven from a valve linestage or a pick-off from the driver of the SE amp that will be driving the Horns and G3 ribbons . I'm hoping the Class-A and feedbackless nature of the F4 will help integration between bass and mid sections . I should at least get the same sort of spatiality from the F4 as a valve SE amp . Mark |
#7297 |
Audio and Loudspeaker Design Guidelines |
#7298 |
Audio and Loudspeaker Design Guidelines Last edited by mige0; 9th September 2010 at 05:40 PM. |
#7299 |
Any more news on Gary's progress?
#7300 |
I can give a quick update...
The low pass filter for the TD15M is finished and came out beautifully (in terms of the rolloff shape, IR and CSD). The high pass filter for the Radian 745 is in progress. The circuit has been simmed but not yet built. I was waiting for some autoformers and custom inductors from dave slagle (Intact Audio) and other various parts, but everything's here now. I will have a chance to put them together and run some tests this weekend. With any luck, I'll get to hear some music through them very soon! (getting tired of test signals...) Gary Dahl
"So many tubes, so little time..." |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.14662 seconds (60.67% PHP - 39.33% MySQL) with 11 queries |
