#7231 | |
John k.... Music and Design NaO Dipole Loudspeakers. |
#7232 |
I think we can safely say that voltage drive is equivalent to current drive feeding a decent driver when equalized to same response (practically by measuring the driver's current IR when fed with voltage drive, then convolving signal voltage with that IR to get the required current drive signal). The difference will be distortion and large signal behaviour.
Assumed is a driver's mechanical construction that is a pretty stable and linear system even without any electrical damping. Then current drive can yield lower distortion because any change of impedance and hence any distortion coming from that is completly factored out (note that sometimes parts of this distortion might partly compensate certain other distortion mechanisms). Above resonance true current drive is not a problem, typically. With woofers used around resonance net improvement may be not big at all; when the woofer's resonance shifts or mechanical damping is non-linear then true current drive can easily give greater error than more voltage-like drive. Under large signal some woofers even show chaotic behaviour with pure current drive. An example of a comercially available active speaker using variable impedance drive for the woofer (low around resonance and rising slope above that) and current drive for the tweeter is Grimm Audio's LS1 (designed by Bruno Putzeys). Klaus Last edited by KSTR; 18th August 2010 at 06:16 PM. |
#7233 |
Location: Austria, at a beautiful place right in the heart of the Alps.
I beg you - don't give up on standing firm as a rock (in *this* case)
![]() Michael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 18th August 2010 at 07:41 PM. |
#7234 | |
But one of the problems with current drive is the possibility thermal runaway. As the driver heats up in a voltage drive system the VC impedance rises and for a given voltage drive level the current is reduced, reducing the rate of heat generation. Further increase in VC temp yields further reduction in current and rate of heating. But with current drive the current remains fixed as the VC heats up and the increase in Re thus results in an increase in VC heating rate, further increasing in VC temperature, thus further increasing the rate of heating...... In the region well above resonance where the electromotive damping is decreasing with frequency at 6dB/octave, the potential distortion reduction due to current drive become a dismissing factor as the driving force is dominated by the forward current.
John k.... Music and Design NaO Dipole Loudspeakers. Last edited by john k...; 18th August 2010 at 09:02 PM. |
#7235 |
When I am in error I correct it , ASAP.
#7236 |
"So many tubes, so little time..." |
#7237 | |
If a power amp - tube or transistor - requires a flat impedance load, it's no good, no matter how famous the name or what a magazine reviewer says about it. As I get older, my tolerance for incompetent designs sold at extremely high prices is going down. I'm not a rocket scientist, but the Amity and Karna amplifiers weren't that hard to design, and that was working from a clean sheet of paper, instead of copied from a 1950's Dynaco, Fisher, Marantz, Radford, or Quad II. All I did was work out the load-lines and calculate the peak and quiescent currents. If I can design an entire amplifier with a 30-year-old HP15C calculator, anyone can. The 2004 ETF presentation summarizes my thinking on amplifier/speaker interface issues. Where the loudspeaker back-EMF's end up is important, particularly since back-EMF's are not just lumped RLC analogs, but also contain (at lower levels) narrowband contamination from driver resonances and driver nonlinear distortion. Sinking these distorted currents can be done in the crossover (with shunt elements) and is also done in the power amplifier. Damping factor, as it is usually considered, makes an unwarranted assumption that the amplifier is distortionless, and a result, has an output Z that corresponds to an idealized resistor. This is not true in real amplifiers, which have dynamic, nonlinear output impedances that are mostly, but not completely, linearized by feedback. The degree of approximation to a ideal resistor is a function of the amount of feedback; to the extent that feedback is not infinite, there are traces of the output devices switching on and off (Class AB artifacts), as well as failure of complementarity (distortion cancellation) of the output devices. The instantaneous variations in current gain as the output waveform goes through its duty cycle interacts with the back-EMF's sent from the driver to the amplifier. This is audible, and the degree of audibility depends on the loudspeaker. The essence of why amplifiers and speakers interact unpredictably isn't a simple matter of output Z versus crossover sensitivity to source impedance; if that were so, tube amps could be mimicked by simply adding series resistors to the outputs of transistor amps. It's not quite that simple. This is why I pay attention to decoupling driver back-EMF's from the power amp, and don't completely trust feedback to clean up the mess at the output devices. Linearization of the output section, particularly with respect to having constant current gain throughout the output waveform, makes the job of feedback much easier. However, designing a Class AB output section (tube, transistor, or MOSFET) with constant current gain is very, very difficult. Last edited by Lynn Olson; 18th August 2010 at 10:36 PM. |
#7238 |
As a quick followup, I should mention that many high-end amplifiers, both tube and transistor, are marketed as "Class A" when they are nothing of the sort. A quick calculation of quiescent power dissipation on a per-device basis reveals that many OTL, push-pull pentode, and bipolar and MOSFET amplifiers are only in Class A in the 1 watt (or less) region, with the switch-off of complementary devices already accomplished by 5 watts RMS. This can be confirmed by measuring current draw on the power-supply rails as the power devices enter and leave the Class A region.
This has the consequence of instantaneous changes in current gain as devices switch on and off, which results in a corresponding change in instantaneous output impedance for the amplifier as a whole. As mentioned in the previous post, feedback can linearize this, but it cannot remove it completely (unless the amount of feedback and forward gain is infinite). The slight-of-hand of the advertisers centers around minimization of hard switch-off in the power devices, and this is passed off as "Class A" because it fools the THD meter. But THD is not a good way to measure Class AB transitions, because the transient disturbance is so brief relative to the signal cycle. It takes very severe crossover distortion to affect THD measurements. Spectral techniques are better, looking for HF artifacts, but they too are affected by the relatively brief duration of the switching artifact. Time-based techniques are more revealing, and the most direct and accurate method is analysis of current draw through all the power devices. True Class A with well-matched complementary devices has a very close to constant-current draw (typically 1% variation) on the power supply, while other output types have much greater variation in current draw over the signal waveform. The variation on current draw on the power supply not only has implications for back-EMF interaction, but also radiation of distorted current pulses into the rest of the power amplifier from the power supply rails, as well as radiation of (very) distorted current pulses from the power cord into the rest of the audio chain. Last edited by Lynn Olson; 18th August 2010 at 11:09 PM. |
#7239 | |
#7240 | |
Decoupling back EMF or any kind of stored energy from the amp is always a good idea. This is also why I mention requirements for flat impedance. The more gradual the slopes in the impedance generally is an indicator of less energy stored in the circuit. Attached is an impedance example of (if I recall correctly) a two way MTM small speaker in ported enclosure(s) crossed at around 10KHz. Attempt was make to smooth out the impedance adding as little components as possible, even the two peaks normally exsiting in ported enclosures were no exception. Listening was conducted on a HAFLER XL-280 amplifier. Very interesting that you mention the sensitivity of swapping speaker cables. I've recently been doing some measurements with interconnects also with similar findings. I'm gradually going through my lot of interconnects to figure out correlation.
Hear the real thing! Last edited by soongsc; 19th August 2010 at 03:11 AM. |
