Beyond the Ariel
Beyond the Ariel
Old 16th August 2010, 02:23 AM   #7191
Pano is offline Pano  United States
Pano's Avatar
Beyond the Ariel
Interesting. I have a buddy on Maui who bought Arum Cantus tweeters to augment his P.Audio 12" coax drivers on OB (IB subs) He is very, very happy with them.
Take the Speaker Voltage Test!
Old 16th August 2010, 06:02 AM   #7192
g3dahl is offline g3dahl  United States
g3dahl's Avatar
Here's the impedance/phase plot for the Radian 745-8PB on the Azurahorn AH-425:
Gary Dahl
"So many tubes, so little time..."
Old 16th August 2010, 06:24 AM   #7193
dantheman is offline dantheman  United States
dantheman's Avatar
Cool Gary. You wouldn't happen to want to post the impulse response for the Radian/Azura would you? It might be cool to see what everyone comes up with. Looks like the crossover will be relatively simple for a CD/15" MW. Nice driver selection!
Dan
My Blog
My Music Recordings
Old 16th August 2010, 07:02 AM   #7194
CLS is offline CLS  Taiwan
Just curious.
Can Radian 745-8PB (w/ Azurahorn AH-425) work with the rear cover removed? Or, how well can it operate like that?
Would it be possible to analyse theose peaks on the impedance sweep (and the effects on performace)? What would be the possible reasons for that one on 1.2kHz? Phase plug or read chamber?
I haven't seen many CD measurements, but I guess the HF behavior of this big guy must be very good.
Old 16th August 2010, 06:03 PM   #7195
g3dahl's Avatar
I set up for measuring the impulse response of the Radian/Azurahorn combo. Distance is 1.5 meters. I have attached the corresponding files in .pir and .wav formats. Vertical scale is arbitrary; the gain of my power amp hasn't been accounted for. The mic preamp doesn't invert phase, so it's probably the power amp, a Parasound HCA-1500A.
The Radian drivers are Lynn's, so I'm not going to open them up unless he wants me to.
Here's the IR for the Radian 745PB-8 at 1.5 m:
Here's the FR from the same setup:
Gary Dahl
Old 16th August 2010, 06:21 PM   #7196
doug20 is offline doug20  United States
Originally Posted by g3dahl View Post
Picture time!
Im impressed!!! Very well done! Any XO info?
Old 16th August 2010, 06:42 PM   #7197
g3dahl's Avatar
Thanks Doug!
Crossovers don't exist yet. Bass cabinet (PR-loaded TD15H) will be powered by a plate amp. TD15M, Radian 745 and G3 ribbon will be passively crossed over at ~600-800 Hz and ~8 kHz. Attenuation for the Radian will be carried out using an autoformer.
Just managed to complete impedance curves, so crossover design is the next step. Anyone wanna help?
Gary Dahl
Old 16th August 2010, 06:46 PM   #7198
Saurav is offline Saurav
I could try if you were using a DCX2496. I'm no good at passive crossovers
Old 16th August 2010, 08:02 PM   #7199
Elias is offline Elias  Finland
Elias's Avatar
I plotted some wavelets from the RAdian/Azurahorn IR file.
Here's a 'CSD' equivalent wavelet:
Here's amplitude normalised to see better the temporal effects:
Above 8kHz it's crap.
Here's constant Q transform, and it's reassignment:
Can I see consecutive reflections/diffractions? Either the driver, or the throat-mouth ping-pong?
- Elias
Old 16th August 2010, 08:06 PM   #7200
g3dahl's Avatar
Above 8 kHz looked like crap on the arta csd too, but on your graph it actually looks kinda pretty!
Gary Dahl
Beyond the ArielHide this!Advertise here!
