#7101 |
I would be interested in seeing some CSDs if it's possible.
Hear the real thing! |
#7102 | |
Location: Austria, at a beautiful place right in the heart of the Alps.
----------- We possibly can summarize the steady state issue simple : IR (as the time domain aquivalent of FR) is the „matrix“ to determine how input signals get deformed *and also* FR (as frequency domain aquivalent to IR) is the end result of that transformation process (input > output) we would hear „SPL wise“ after infinite time = steady state. So we are running a little bit in circles here. I guess thats been what Elias was focusing on. I'm definitely with him that the steady state SPL plots do not sufficiently tell us what we "hear" - given the dynamic structure music distinguishes from "steady state". It needs some additional "reading the tea leaves" to get a good grip on the time behaviour with only a FR plot at hand - Time-freqency plots are IMO more intuitively to read in this respect. The topic IMO is interesting in so far, as CMP can be seen to reach „steady state“ immediately – immediately at „time = zero“ and for the second part at exactly „time = time delay“ - and lastly for the "tail" as well Which is untypical for any other time dependent variations in SPL (= resonance) Besides that – and also to come back closer to the threads topic – I guess the most interest would be in how would a „as good as it gets“ EQ'ing of CMP look like – respectively – what are the artifacts of CMP distortion left. Possibly - *if* we consider the 2.3 ms wiggle as a pure and simple reflection somewhere in the TD15M driver (which in reality most likely isnt *that* simple, but just for the sake of simplicity) - we could hypothesize a „as good as it gets“ EQ'ing and then check how the remaining CMP distortion possibly looks like ??? Michael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 11th August 2010 at 04:31 AM. |
#7103 |
So, after all this discussion (interesting as it is), has anyone bothered to get a strobe and look at the spider to see if it is the source of the 2.3ms wiggle?
Did anyone else explain the polarity inversion of the pulse? Tonebursts at 2.3ms intervals could be revealing. Mike |
#7104 |
I was under the impression that there was no intension to tweek the driver.
#7105 | |
#7106 |
I think someone mentioned that possibility a few pages back. I was wondering whether that could happen to a spider at 2KHz or not. The only way to find out is to tweek it.
#7107 | |
The frequencies contained within the wave packet could be as high as 2kHz. Group velocity - Wikipedia, the free encyclopedia Wouldn't it be cool if it was a physical manifestation of a de Broglie wave? |
#7108 |
The impulse does not show that occuring.
#7109 |
#7110 | |
