Beyond the Ariel - Page 703 - diyAudio
Old 6th August 2010, 12:53 PM   #7021
john k...'s Avatar
Now, keep the end of the window where it is (red line) and move the start to just before the main impulse. Then we will have something I think will be meaningful.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 6th August 2010, 01:10 PM   #7022
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
In case some might like to look at the CSD of that „cut out“ reflections :
Full dampening
Less dampening
Zero dampening
Last CSD plot (zero dampening) tells us that the peak at roughly 1kHz is building up after some time :
Michael
Old 6th August 2010, 01:31 PM   #7023
mige0's Avatar
Ok – here we go:
Full dampening
Less dampening
Zero dampening
Michael
Old 6th August 2010, 03:45 PM   #7024
dantheman's Avatar
I can't see where have more room reflections make anything more meaningful. Just me I suppose,
Dan
My Blog
My Music Recordings
Old 6th August 2010, 06:37 PM   #7025
KSTR is offline KSTR  Germany
KSTR's Avatar
I was really scratching my head about this wiggle of the TD15M. Looked up half a dozen responses of 12" & 15" drivers at Brandon's Driver Measurements - drivervault and all had that same thing more or less.
I think it is a delayed damped back-bounce from the shockwave through the type of spider used for that sort of pro drivers, isn't it? Or is that too simple?
If it were stable (linear) and predictible in character pre-distortion of the driving current (per FIR-filter in the digital domain) should be able to correct for this, trying to terminate the reflection mechanically. Essentially the same strategy that digital room-equalization tries to use, but this time the dimension of the problem is 1, it's 1D and therefore much better suited to impulse response correction techniques, to the extend that the effects are not too non-linear (drifts included).
Ony may argue though if it's worth the effort, or favorable at all, besides the "digital stuff" involved. Well, maybe that delayed wiggle is part of the trademark sound of this class of drivers...
Old 6th August 2010, 07:30 PM   #7026
mige0's Avatar
Delay time of 2.3ms seems to be too long for that to enter the picture IMO
*If* its in the driver itself, I'm rather with John K that it may be from cone modes in break up.
There is another reflection to be identified earlier on (and slighty higher in frequency) but not exactly half of that 2.3ms - so it might or might not be part of the mechanism - for sure its *not* a simple looped reflection, otherwise time would be pretty exactly halved and also we should see pronounced subsequent reflections later on.
There is also a specialty with those speakers in general - the are more of a horn . actually a moving horn - than other speakers, as they have no dust cap and hence more "horn length"
It could well be we see an interference (beat) of the sound created at the throat+ "amplified by the horn" with the sound created at the rim.
Michael
Old 6th August 2010, 07:48 PM   #7027
dantheman's Avatar
Micheal, check back a few pages for my graphs on a pro 12" driver and the effects of damping the cone on both the impulse and break up.
Dan
My Blog
My Music Recordings
Old 6th August 2010, 07:49 PM   #7028
KSTR's Avatar
Yes Michael, seems you are right. I've gone through the recent posts more thoroughly and have to agree that it most likely is breakup (and not a cabinet reflection either... Ockham... now I got it). Anyway, interesting how it sounds in slow-mo and how long the delay is...
Old 6th August 2010, 08:12 PM   #7029
mige0's Avatar
Dan
Are you referring to this one ?
Beyond the Ariel
Beyond the Ariel
Beyond the Ariel
If so - what are you telling us ?
I didn't got the point and also how its related to Dan's measurements ?
Michael
Old 6th August 2010, 10:57 PM   #7030
john k...'s Avatar
Originally Posted by mige0 View Post
Ok – here we go:
Full dampening
Less dampening
Zero dampening
Michael
I think just the full 5 msec window tells a lot. That thing is nasty above 1k Hz. Time to look at a measurement with a 500 Hz 4th order LP filter.
Copyright ©1999-2017 diyAudio
