#641 | |
#642 |
diyAudio Editor
I'll make contact with Brown. I agree Lynn, there is just something "right" looking about those 18 Sound horns. The bigger 1" ones are spec'ed for 1.2 and 1.4 Khz. If we are crossing at over 3khz they should be at least big enough. and combined with those little BMS CD's that Lynn found would be economical enough to also get the AC ribbons to compare
Speaking of Supravox, did we speak of them? If so , apologies 12"Alnico: http://www.supravox.fr/anglais/haut_...s/285_2000.htm 12" Field Coil: "with oversize engine of excitation" http://www.supravox.fr/anglais/haut_...5_2000_EXC.htm They are sometimes hard to find I hear , and pretty expensive besides, and used to have quality control issues, but at least they are quite wide range...I think most of these issues are resolved. Anybody actually heard them?Probably Lynn has.. For the moment I like our home grown EDIT: Supravox recommends this tweeter for their open baffle Nothing too distinguished looking about it. Might be an interesting thing to try with "full range" drivers as an alternative to Fostex supertweeters. Not for this project though http://www.bcspeakers.com/download/p...F/more/165.pdf |
#643 | |
I do think of horns as having a more front of the auditorium perspective, though. I like sitting near the front of the venue at a classical music concert. This was convenient when I lived in London because the front area was not the most expensive. When I was a student in Boston, I liked to go to concerts at Symphony Hall. I'd buy a cheap student ticket, and about 10 minutes after the concert started, I'd creep up to an empty seat near the front. This worked well for a few years until one particular time. I moved forward, and was settling comfortably into my seat. Suddenly there was a wide woman in a fur coat glaring at me with an usher next to her. The usher said: "Mrs. Menuhin would like her seat." She was there to see her husband perform, and of course, I was in her place. I like the sound of open baffles as well as horns, so please carry on... and continue to baffle us! |
#644 |
Supravox suggests a nice looking open baffle on this page:
http://www.supravox.fr/anglais/kits.htm#panneau |
#645 | ||
#646 | |
Others would be better able to direct you to new drivers built like this. I'm more into the old stuff. |
#647 |
Since ribbons are back in the chat...Images copied from web.
The separate dipole bass unit uses two Lambda 15" hi-Q speakers with an eliptical curve cutout on the dipole baffle pipe |
#648 | |
Hi
http://www.diyaudio.com/forums/showt...14#post1173214 "http://www.diyaudio.com/forums/showthread.php?postid=1173214#post1173214" so it may be just a (my) AMT hype? I am currently listening to the ADAM Monitors P11a http://www.adam-audio.com/studio/ "http://www.adam-audio.com/studio/" which also have AMT or A.R.T. as they call it. They sound good , very open, and detailled and definitely can play loud but there is also something too bright on it. Maybe its rather from the swiched amp than from the AMT I didn't check that out in detail until now. If someone wants to start it's own low cost production check out this page: http://mywebpages.comcast.net/neilan...DIY1/index.htm "http://mywebpages.comcast.net/neilandbarbaradavis/DIYHeil/DIY1/index.htm" Greetings Michael
Audio and Loudspeaker Design Guidelines |
#649 |
Hi Lynn,
A ToneTubby 8" with a more robust cast frame/basket rather than stamped steel would be interesting to measure... FAL of Japan has a flat type of widerange neodymium driver (Flat C-90 95db/w/m) but is said to be beamy af HF. Pricey for a pair I think but is said to be very good in OB. Maybe you could xo it in the lower hf ~6kHz? FAL also makes their own high eff Heil tweeters to mate with their widerangers, which might be as pricey as those Mundorfs. Anyways wrt horns, Jean-Michel LC's horns at the ETF 2004 are pretty much the same as the Azurahorns as they use the same expansion, except for the material used. I think JMLC uses horns that use a form of plaster material. http://ndaviden.club.fr/pavillon/exe...photos320.html Jefferey Jackson of experiencemusic.net also has samples of his own made Le C'leach expansion 320Hz horns (t'was at RMAF). Maybe he can lend you his pair? Jefferey used slagleformer attenuators for the compression drivers. The Fostex autoformers (1dB steps) are quite on the pricey side. For narrow width listening rooms, I think a pair of "very good" horns would be a good thing to avoid early reflections from sidewalls. Even if using small format compression drivers, and if let's say a phenolic diaphragm (vintage driver) that limits the HF ~8k natural roll off, one could still augment it a with a very good supertweeter. |
#650 | |
http://www.lampizator.eu/
Jose Carlos |
| Page generated in 0.17486 seconds (72.22% PHP - 27.78% MySQL) with 11 queries |
