#5561 | |
Once again the subjective sense of "speed" under discussion is NOT with regard to how quickly the driver can oscillate (or by result, how high the freq. extension is near the average). That Adire paper is not only useless in this instance, it actually is a disservice to the discussion. (..and one in which I've admonished the author for here in this forum.) The paper was specifically an attempt to say "Hey look here, our woofers can oscillate quickly thereby *proving* that our high mass high excursion low eff. subwoofers are "fast"!". Of course he knew fully well that what people were describing as "fast sound" had nothing to do with it's ability to oscillate quickly.As for the rest - again, its a general guide to achieve specific subjective sound. In this respect: A. you don't seem to recognize what people are describing when saying a driver sounds "fast" or "not". B. you are arguing a topic that "A" you appear not to fully comprehend, and that you are arguing that a "guideline" is inaccurate because the underlying principal is incomplete at best - which is irrelevant. The guideline isn't there to say the guideline is correct, rather it's there to say you are more likely to achieve sound "x". (..fundamentally that's a rather substantial difference - think about it. )
perspective is everything |
#5562 | |
Hi Earl, We basically agree here. Increasing mass has to change the drivers Fs and thus the impulse response, although it won't be seen in the initial rise, and is probably difficult to see in the impulse tail. However, there is also the possibility of a resonance at the high frequency cut off of the driver where the of the driver mass may resonate with the voice coil inductance. I don't know how significant this is, but in theory it is possible. This could be apparent in the initial rise of the impulse.
John k.... Music and Design NaO Dipole Loudspeakers. |
#5563 | |
At last, a statement that I can agree with. It's not that I don't agree or disagree with the others, it's just that with terms like "speed" and "impact" - that clearly mean entirely different things to different people - whats being said doesn't make enough sense to agree or disagree with. |
#5564 | |
Hear the real thing! |
#5565 |
My take on this is the the idea of speed and impact as related to a driver are pretty much nonsense. Adding a series inductor is not the same as changing VC inductance. The series connection acts more like a shelving filter, lowering only the amplitude of the signal applied to the driver starting at about f = Rc/(Ls + Lc)/2/Pi where c = coil and s = series. But the effect is the same, increased group delay, attenuated high frequencies.
So what would the impulse look like if the woofer were low pass filtered as it would be in actual use? (rhetorical question) That is what is relevant. If the woofer is to be used only to 200 Hz or whatever, what matters is what the impulse of the filtered woofer looks like. That will be a function of the filtered response. If the filter is designed to a specific acoustic target, then any woofer with the same Fs and Q will have the same impulse when filtered to the same low pass acoustic target. So all that so called "speed" is irrelevant since it is an artifact of what the raw driver is doing above the corner of the LP filter. The woofer LP filter sets the "speed" of the impulse rise as used in a speaker. It seems the audio will forever be a discipline where science is treated as the enemy rather that the path to progress.
#5566 | |
#5567 |
Put a 200 Hz LR4 LP filter on them both and look at it again.
#5568 |
not exactly sure how to do that in SE.
#5569 | |
#5570 | |
Tom |
| Page generated in 0.19755 seconds (70.47% PHP - 29.53% MySQL) with 11 queries |
