Beyond the Ariel
Beyond the Ariel
Old 6th May 2009, 04:48 PM   #5391
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
Thaks Earl - I'll take your offer - just PM me.
Michael
Old 6th May 2009, 05:24 PM   #5392
mige0's Avatar
Regarding signal to noise ratio for CSD measurements.
The measurements I have shown recently have been taken in doors - but with no special care to ambient noise.
I may have had roughly 40 - 45dB noise floor which leaves 45dB S/N for the measurements at 90dB SPL.
This is not great at all - but still comfortable for the intent. We don't have to be too picky in this IMO.
Furthermore you immediately see the noise floor if we change unsual 25dB scale of CSD to - say 50dB.
Its really a *floor* that is displayed, if you have a PC rumming close by also the dominat frequencies of the vent and HD as something that sticks out and does not decay.
So very easy to identify...
Michael
Old 6th May 2009, 05:44 PM   #5393
gedlee is offline gedlee  United States
gedlee's Avatar
Michael
Since I do a cross correlation, the noise is not room noise as the measurement is immune to that, its more calculation noise and limited averaging that is the problem.
Earl Geddes Gedlee Website
Old 6th May 2009, 07:13 PM   #5394
mige0's Avatar
Ok - I remember you having once said that you do not use commercial software (like ARTA for example) for your analysis but do the coding by yourself (in mathcad IIRC).
I guess the crosscorrelation you mention is related to that process?
Does it mean that the artefacts of calculation done there are not evenly spread like a "floor" - making CSD post processing from your impulse extraction less usefull as usual?
Not sure if I got your point.
Michael
Old 6th May 2009, 07:32 PM   #5395
gedlee's Avatar
They will generally appear as a floor, its not caused by room noise thats all. My room noise is quite high with no end of noise interuptions from cars, airplanes, kids, HVAC, you name it. Without noise imune signal processing the data would be quite useless.
Old 7th May 2009, 04:18 AM   #5396
mige0's Avatar
Courtesy Earl
OS wave guide at 0 deg:
OS wave guide at 15 deg:
OS wave guide at 30 deg:
OS wave guide at 45 deg:
48kHz Files provided by Earl I converted in CoolEdit and processed by ARTA to get CSD.
Looks pretty much excellent for me with respect to decay time
Michael
Old 7th May 2009, 06:38 AM   #5397
xpert is offline xpert  Afghanistan
Account Disabled
Noise will have its impact regardless of cross correlation. What then is "room noise" opposed to what? Not caused by room noise but shows as a floor. Room noise is ... example given: airplanes. A bit confusing to me.
CSD is quite useless. One would have to know which deviation from ideal is critical or not. The threshold of perception, related to the graphs is where? CSD is nothing but the impulse response. To estimate the impact on audio reproduction the better way is to look at (1) amplitude over frequency and (2) group delay. CSD is nothing else, really. It's apperance leaves room for some free style interpretations. But that means nothing but confusion. Every technical info on audio transducers should be related to psychoacoustics. But it can't be done - honestly - with CSD pictures. CSDs can be compared to each other. But what does a difference tell about sound quality?
have fun
Old 7th May 2009, 06:53 AM   #5398
Jmmlc is offline Jmmlc  France
R.I.P.
Hello mige0,
It seems that the window rise time of the CSD you obtained using Arta on Earl's pulses is not the same that you used previously for the CDS in your message:
http://www.diyaudio.com/forums/showt...79#post1818279
Could you indicate the parameters used to obtain those CSD:
FFT size
Window rise time
Slice shift
Smoothing
(you said in your CSD comments that the decay was excellent, could you specify the frequency above which you consider the decay being excellent...)
Best regards from Paris, France
Jean-Michel Le Cléac'h
Michael
Old 7th May 2009, 09:12 AM   #5399
Telstar is offline Telstar  Italy
I beg to disagree.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 7th May 2009, 09:38 AM   #5400
Account Disabled
Originally posted by Telstar
I beg to disagree.
Granted.
Beyond the ArielHide this!Advertise here!
