#521 |
Interesting. Of all the coaxes, the Beyma's look most interesting. Their 12" bass drivers look pretty good too.
#522 |
#523 |
#524 |
diyAudio Editor
The original Bastanis Promithius used a Beyma tweeter with their Eminence woofer I believe.
#525 | |
diyAudio Editor
I checked: Darn! 92dB / 2.83V / 1M not efficient enough! Well.... the Phy drivers use piezo tweeters.... ![]() OK the Aurum Cantus 2si ribbon has a diameter of 4-5/16" (110mm) but the flange could be removed and easily machined to less than 4" without damage as you can see from the link below.It's 96 db http://www.e-speakers.com/catalog/au...si_4284956.htm Hmm I wonder if the pressure would damage it? I have a 2si 4.5" laterally away from a 15" woofer and no problems so far... |
#526 | |
frugal-phile(tm)
I have a set of AC here with custom 104.5 mm bezels... it could be smaller yet, 93 mm by my drawing. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#527 |
To make things more simple, why can't a good efficiency dome go in a 90deg constant directivity waveguide to match the efficiency of the woofer. My limited research and experience with waveguides tells me that a dome with a CD waveguide in front would be easier to get right than a CD WG for any other driver. You want the wave front edges perpendicular to the waveguide sides. Typically a lot of trouble or size goes into getting the necessary spherical wavefront shape entering the waveguide. With a dome the wave starts out the proper shape, so no throat is needed.
The only compression driver I ever opened up had a dome membrane in it producing the sound, and what a cluster f#$& the sound had to go through to get to your ears. Radiating from a dome straight into say a 90deg WG seems a whole lot simpler to me, and if you can get the woofer up to 4-5khz, the WG doesn't need to be very big. Radiating 94db/w/m into half space has to get close to your efficiency goal radiating into a 90deg CD WG. With the CD WG you should even run into far less problems related to the woofer operation interfering with the tweeter operation, IM etc. The whole thing seems so simple to me that there must be some basic flaw, unless the manufacturers are just out to sell you the high priced compression drivers. Why else would they insist on strapping a 106db/w/m compression driver to a 99db/w/m woofer. Let's make our own 99db/w/m tweeter. Am I that far off the mark?
Everyone has a photographic memory. It's just that most are out of film. |
#529 |
My small contribution...
I would like to contribute but I have very little speaker knowledge but a reasonable ear for music (musician). Most of this stuff is over my head. I've noticed the TT Alnico is edge wound, no information on the ceramic TT VC construction (round wound?). All the coaxes mentioned here (unless I've missed some) are not edge wound. Some of the pro sound non coaxes are edge wound from the same vendors with coaxes. Not sure if the VC construction has any relevance, but I must say the 12" TT alnico have amazing mids. Regards Frank. |
#530 |
diyAudio Editor
Dave, 93mm doesn't surprise me. It could be done. You are Mr. Phaseplug
so I'd think you'd be tempted. A nice turned wood nose tht tapers from 100mm to 93mm,that fits into a 4"tube which attaches to the polepiece. The tube could just have a piece of steel inserted on the inside end which I would presume would snap right onto the magnatized polepiece. Carefully!!! like the guys that use a socket wrench socket as a phaseplug. At the moment I cross to the 2si at about 4500 hz and I like it! At 96db it probably is about the right efficiency to work with 97 Db drivers. People say that padding down a ribbon hurts the sound. I don't have to pad mine down because it matches the mid efficiency so well. That is really elegant IMHO. I think most of the rear of the ribbon is magnet. It's just that additional bump which I think is the transformer, but I'm just guessing. I don't know if any hemp 12" drivers have 4" coils though. Quite likely the Super Boy 15" with cast basket does, but ceramic magnet and how high does it go? Might have to use the eighteen sound..or some other for an experiment. I don't have measuring equipment. http://www.6moons.com/audioreviews/b...metheus_2.html John, Here are the new Bastanis tweeters. As you mentioned, they are the insides of a compression driver made to work with a custom horn(below link) I do believe that he leaves the backplate off to get dipole action! The 6 moons site shows this. They look like they could be used as dome tweeters, but without compression, their efficiency might be as low as other dome tweeters.I don't know Also compression driver magnets are pretty huge. They wouldn't fit in a phase plug... All commercial dome tweeters that I have found top out at 93 dB which really isn't enough for what Lynn wants. I think he'll accept 97 dB but I think he dreams of 99 dB http://www.bastanis.com/catalog/index.php?language=en http://www.bastanis.com/us/atlas.htm |
| Page generated in 0.18553 seconds (71.82% PHP - 28.18% MySQL) with 11 queries |
