Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 20th February 2009, 12:40 AM   #5001
chrismercurio's Avatar
Lynn,
Can you post or point to a picture? Maybe I should still try to build that Auditorium 23 SoloVox knock off for the 604 and see what happens (sonically).
Chris
Old 20th February 2009, 01:15 AM   #5002
angeloitacare's Avatar
Lynn
i know you are concerned about natural tone, and want to avoid coloration as much as possible.
I have bought and tried recently a pair of Audax Medomex 6" papercone drivers.These are predecessors of the Audax PR170M0. These have not the clarity, and are not as much revealing and dinamic as Lecleach/S2 horns. I have tried the S2/LeCleach, crossing at 500hz/1000hz/2500hz , 6db slope, and midbass accordingly. Crossing at 1000hz, i got the best results. When it comes to play music specially with voices, the Audax sounds far more natural / neutral / coloration free.
It is however not as much revealing and dinamic. Since i do listen more instrumental / jazz etc. , i prefere horns. But the Audax PR170M0 has 99db/wm. I guess in a short wave guide, it might be a interesting compromise. It certainly will be much more tonally accurate and close to the original event, than any solution with a horn in the midrange channel. I think it would also be a great match with your RAAL's. My observation does correlate with others, like Magnetar and Aleks :
http://www.audiovoice-acoustics.com/...read.php?t=672
I'm weaning off JBL compression drivers. IOW the Audax pair even when ran up high is still distinctly superior in smoothness and tone over the 2440's I am used to and also has the dynamic/presence character I like.
Aleks made a comment about the PHL 1120, which is very similar to the Audax PR170M0 :
Ever tried PHL? Its Phillipe Lessage, ex Audax head-designer that opened his own company. He has a few amazing midrange spekers like 1120, for example. I used them and they are phenomenal.
Angelo
Old 20th February 2009, 10:29 PM   #5003
Lynn Olson's Avatar
Originally posted by chrismercurio
Lynn,
Chris
From the Onken thread ...
Originally posted by IslandPink
"It would be interesting to combine the 45-degree slant edges of the HF Olson RCA LC-1A speaker with the double-wall Onken vents. This would substantially lower diffraction and retain the double-wall lossy vents of the Onken. Another clever variation would be to have different thicknesses of cabinet wall for the inner and outer surface, which would stagger the wall resonances, and make acoustic coupling from one to another less efficient."
This being a good start point then - ?
http://www.supravox.fr/kits/jensen.pdf
http://www.supravox.fr/anglais/kits.htm#Jensen
MJ
Is that what you were thinking of?
As for the Audax ... um, well, I heard them a long time ago, back in the late 70's, and I thought they were reasonably good drivers that didn't require a lot of equalization. As I recall, they had very short Xmax, and were essentially midranges requiring a 200~300 Hz crossover for satisfactory performance.
In terms of smoothness and freedom from resonance, the Vifa 5.5" drivers in the Ariel are significantly flatter, have an extremely well-behaved rolloff region, and very rapid decay characteristics. But the efficiency is nearly 10 dB less, not a small difference. And using drivers in arrays does NOT give the same performance as a single, higher-efficiency driver. Just hassling with a pair of drivers added many months of hassle to the Ariel project - and that was with drivers that are as close to technically perfect as anything I've ever used. The prospect of using 2 or 4 drivers that are rougher, and have more pronounced breakups in the 3~10 kHz region, is very unappealing. The current fashion is brute-force 24 dB/octave crossovers (or ignoring the coloration), but I don't want to go down that path.
I tend to have strong go/no-go reactions to drivers. If I hear something special - an especially lyrical midrange, HF, or bass (in that order), I take note and try to find out what's going on that makes it special. I basically discount other people's opinions - sorry, no offense to anyone here - unless I know them and their taste personally. So I give weight to Gary Pimm, John Atwood, and Alexander, although I think Alex and I have different tastes in the midrange.
I haven't heard the new Jean Hiraga 604 Duplex, for example. The last time I heard a traditional 604, the midrange was one of the most colored and aggressive-sounding I ever heard, so the magnitude of the task facing Mr. Hiraga was enormous. On the other hand, he is one of the most experienced audio designers in the world, and has excellent tastes musically - so if anyone could pull off the near-impossible, it would be him. I wouldn't even attempt what he's done.
Sometimes I wonder why anyone listens to me. I'm a pretty lazy designer, and try and use the most linear devices I can find (flattest response, least energy storage, etc.) so I can concoct something around that. I kind of admire folks who visualize a Platonic Ideal of a loudspeaker, and work from the top down to bring the realization to the physical world. I just look for the prettiest pebbles on the beach, and make something around them.
Old 20th February 2009, 10:41 PM   #5004
More along the lines of a deluxe version of this:
http://www.6moons.com/audioreviews/a...2/solovox.html
I am curious about Gary's enclosure though. Do you have any pictures of that? I like the links to the Jensen enclosures.
Thank you,
Chris
Old 20th February 2009, 11:45 PM   #5005
Lynn Olson's Avatar
There are some pix in the Issue 20 article of Positive Feedback magazine. Dave Robinson, the editor, lets me get away with an over-the-top style - so it ended up as a mashup of film noir, science fiction, and audio. Portland still looks a lot like the 1936 pix, by the way - just add water glistening on wet pavement, and the Chandler mood is already set. (Many inside jokes for the entertainment of the Portland Triode Society - all the locations are real.)
The last I saw of Gary's system (a couple of years ago), the mids were in open-ended boxes filled with Bonded Logic Ultratouch insulation, made from recycled blue jeans. This stuff has none of the scratchiness of fiberglass, and has very good broadband acoustic absorption. Think of a 1-cubic-foot wedge of the stuff in the mid and bass enclosures, and you get the picture. He also used a lot of rope caulk to quiet down the stamped-metal frames of the Beta 8's.
The crossovers are low-Q, low-order passive networks between the ribbon tweeters and the Beta 8's, and active Behringer lowpass for the damped-dipole W-baffles for the subwoofers. The subs use pairs of 15" drivers for each channel, and the heavily-modified Behringer is kept out of the mid/high signal path - all it does is EQ the woofs for the room and roll them off before the W-baffle goes into its first mode.
Old 20th February 2009, 11:59 PM   #5006
Another great thing about Bonded Logic is the price. Since it is marketed to home builders its very reasonably priced unlike the "special" audio grade stuff. I agree that the ST and NRC numbers for the material are excellent. I will look up the issue after I go home. Long day today,
Chris
Old 21st February 2009, 12:19 AM   #5007
Lynn Olson's Avatar
I really like this picture - it's astonishing that downtown Portland still looks so much like this. Entirely appropriate to the 1935 vintage of the Western Electric 300A/B and the WE 86 and 92 amplifiers with Class A PP and Harmonic Balancer topologies. It's a good question which amplifier the "Liberty Theatre" used - the 92, 86, 43, RCA, or maybe it was a burlesque theatre. Probably not the latter - Broadway was the main street back then, and still is today.
The image quality of the Speed Graphic that was probably used for this picture had nothing to apologize for, either. The 16 x 20 print from the Oregon Historical Society that I scanned for this pix looks really good.
Old 21st February 2009, 12:59 AM   #5008
panomaniac's Avatar
Originally posted by Lynn Olson
The last I saw of Gary's system ... the mids were in open-ended boxes filled with Bonded Logic Ultratouch insulation, made from recycled blue jeans.
Yes, still the same. (Quite an impressive system, BTW. Clean, clean, clean).
Here is a link to a very good group of tables showing Absorption Coefficients and NRC for many, many materials. Roxul, Bonded Logic, Owens Corning, etc.
http://www.bobgolds.com/AbsorptionCoefficients.htm
Old 8th March 2009, 03:02 PM   #5009
soongsc is offline soongsc
soongsc's Avatar
Wondering how the project is going.
Hear the real thing!
Old 27th March 2009, 06:23 PM   #5010
kevinh is offline kevinh
Default Any updates?
Hi Lynn any updates on the driver testing?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Zeverin
Thread Tools
Page generated in 0.18952489 seconds (75.23% PHP - 24.77% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
