#491 |
Variac... the heil uses a horizontally pleated membrain that looks just like an accordian. When the driver is fed a signal the pleats squeeze together on the front side and open on the back side then the cycle reverses. So like a bellows while it pushes on the front side it is drawing in air on the back. If it were a simple case of horizontal push and pull then it would behave as a bipole. Regards Moray James.
moray james |
#492 |
Moray,
That price quote was for the 6.5 cone wideband ceiling driver unit in a can. The 6.5 coaxial ,driver is ~$400, which could easily be bettered IMHO.... I agree, whizzer "fullrangers" are out.
"Pilau Buggah, Big Islan Mo Betta!!" |
#493 | |||
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#494 |
versions are less expensive than ceiling but yes I agree that is getting up there. Will check into the prices for contractors. Given that these work well they may not be out of contention. Remember guys are paying almost $300.00 US funds for sota tweeters today. So what else would make a short list? What about a 3 -4 inch wide line source ESL with 1 - 1.5 mm gap and lots of tension for good efficiency to get you down to a couple of hundred hertz? Regards Moray James.
moray james |
#495 |
frugal-phile(tm)
If the Tannoys are to be considered, the 12" (in a can -- CMS12TDC) is probably in keeping with Lynn's goals, has a paper cone instead of a plastic (i had a set of the 8" in the Dimension cabinets, while good, i prefer a set of Fonkens)... Still i'd love to have a set of the 4s to play with. The pricing should be -- based on 2000 pricing that i have ($650 USD/pr) -- in the same general ballpark of many of the drivers being considered.
Note that to get these, you have to be an "installer/dealer" so a group buy would need to revolve around one of these (even if it is one of use, just signing up to do this one buy) dave
#496 | |
I'm of the school that is reluctant to "boost" drivers in any part of their range, but am quite willing to apply strategically shaped rolloff curves and notch filters when necessary. As for the Tannoys, I've heard the poly-cone versions, and no way am I interested in those. But the 10 or 12-inch paper-cones at the contractor price - now, that would be interesting! |
#497 | |
I must confess that to some extent I am over-correcting from the Ariel, with its pint-size 5.5" Vifa drivers. Yes, they're ever so smooth and silky, with wonderful vocal qualities, but they run out of gas around 100 ~ 105 dB (yes, I've played them that loud). I want much more dynamic range this time around, at least 10 dB more. Seriously, I do. Now the problem is finding drivers that have even moderately smooth responses, since we've officially left audiophile territory. Then again, audiophile drivers have left me, since the latest crop of audiophile jewels with advanced cones are now as rough, or rougher, than prosound, but without prosound dynamics! |
#498 |
I really wonder if TAD is as good as they are praised. If I'd had to choose just from PA audio (which I am considering more and more) then I guess TAD, Precision Devices, 18Sound and PHL would be the first choices, specialy considering midrange aplications.
Unfortunately my beliefs are based only from review's and rumors; bringing these to discussion and doing a proper selection would be a great benefit. |
#499 |
I was looking for a 12" guitar speaker with smooth response yesterday and stubled upon this speaker.
I'm wondering if it is a candidate for your project? It has smoother (published) response than a great deal of hifi and pro product. It also doesn't have any of the ragged topend or peaky breakup. Just a thought, C |
#500 |
Lynn
Nothing at all scientific, a pair of TT 10 popped out of a Fender Twin and mounted on a baffle, using an EMU 1616 PEQ patch, VERY impressed with the clean, smooth, and ultra-musical reach of the TT 10 Alnico. Clearly higher reach than that indicated on your graph. ...TT send their drivers out for independent analysis, and I explained to them at NAMM that FR plots would be useful for the non-rockers interested in their wares. I am a strong believer in these two drivers.
| Page generated in 0.18167 seconds (72.53% PHP - 27.47% MySQL) with 11 queries |
