Beyond the Ariel
Beyond the Ariel
Old 18th October 2008, 07:48 AM   #4541
Lynn Olson is offline Lynn Olson  United States
Lynn Olson's Avatar
These things aren't easy to photograph thanks to complex internal contours and the silky-smooth internal finish. It's not glossy, but more of a satin finish, with a silky texture that is hard to describe. The junction to the compression driver looks perfect as far as I can tell, no burrs or flaws anywhere.
Old 18th October 2008, 07:51 AM   #4542
Lynn Olson's Avatar
The satin finish looks flat, but isn't - there's a subtle texture there, which can be seen as well as felt. The closest description is "alabaster white".
Old 18th October 2008, 07:52 AM   #4543
Lynn Olson's Avatar
They're not as big as they look - they're actually kind of petite. Karna approves the looks, and so do I. Very elegant and classy looking, and also surprisingly rigid and solid. Much better made than the commercial horns I've seen, no burrs or flashing, and the rigidity is better too.
Old 18th October 2008, 10:22 AM   #4544
mige0 is offline mige0  Austria
mige0's Avatar
Location: Austria, at a beautiful place right in the heart of the Alps.
Lynn - you will have to do *all* audition with your eyes closed - anything else wouldn't be fair !!!
Stunning look - all the best with these...
Michael
Old 18th October 2008, 10:34 AM   #4545
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Beyond the Ariel
Lynn,
I was hoping to meet you at Rocky Mountain
About what is the diameter of the wide end?
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 18th October 2008, 10:49 AM   #4546
mige0's Avatar
Again thanks Bj°rn - for making available the results of your excellent simus.
Michael
Old 18th October 2008, 02:50 PM   #4547
sujith kumar.r is offline sujith kumar.r  India
Default drivers for ariel5s
hi lynn,
Thanks once again for your suggestions, i am actually dumping those drivers.... the other available 5.5 inch vifa driver is TC14WG49-08 ,
t/S parameters TC14WG49-08 are
nominal impedance-8 ohms
voice coil resistance- 5.55
nominal power(W) -35
short term power(w)- 110
operating power(W)- 10
sensitivity (db) -86
frequency range (hz) - 55 - 4000
free air resonance-53
voice coil diameter -25mm
voice coil height- 10mm
air gap height - 4mm
voice coil inductance(mh) - 0.60
effective diaphram area - 80 cm2
moving mass(g) - 78
magnet wt (g)/(oz)- 240/85
force factor(Bt) -- 5.2
Vas (l) - 10.5
Qms - 2.73
Qes - 0.53
Qts - 0.45
OTHER FEATURES:
NRSC cone
high linearity
low loss suspension
NR rubber surround
moulded rubber reinforced polymer chasis
vented magnet system
kindly tell me if this driver can be used for the ariel project...this is the only 5.5 inch driver of vifa available in india currently...and only a few nos are left cos they are closing down the distributership (corrson) cos the DIY volumes are very low......and the only other vifa driver available is 6.5 inch P17WJ-00-08, can it be used with cabinet modifications...kindly suggest......cos we are in a country which sucks for DIY audio fanatics...( I am very sorry to say that) .......kindly give suggestions...... thanks in advance
Old 18th October 2008, 04:05 PM   #4548
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Hi Kolbrek,
After looking at the data and reading the articles you have written, I can't help but wonder how things would look for an OS wave guide with a tube section before the throat would perform. Would very much like your opinion.
Hear the real thing!
Old 18th October 2008, 06:18 PM   #4549
Lynn Olson's Avatar
Default Re: drivers for ariel5s
Originally posted by Variac
Lynn,
Hi Variac, sorry we didn't get together. I was more mobile than last year, and was scampering around the show pretty much the whole time. As it was I only saw a tiny fraction of it, focussing mostly on the high-efficiency and dipole rooms.
The AH-425 overall diameter is 418 mm, and when resting on a flat surface, the part that contacts the surface is about 360 mm.
Originally posted by sujith kumar.r
hi lynn,
Thanks once again for your suggestions, i am actually dumping those drivers.... the other available 5.5 inch vifa driver is TC14WG49-08,
moving mass(g) - 78
Vas (l) - 10.5
Qms - 2.73
Qes - 0.53
Qts - 0.45
OTHER FEATURES:
NRSC cone
high linearity
low loss suspension
NR rubber surround
Plastic chassis - ugh. Have no idea what a "NRSC" cone is. The T/S figure of 78 grams is absurd - that's heavier than many 15" cones! It can't possibly be that heavy. The rest of the T/S data looks reasonable and typical for many 5.5" drivers.
Transmission lines, unlike vented speakers, are not picky about T/S parameters. The filling tends to wash out many differences between drivers, letting the line and stuffing dominate the picture. Aside from the improbable Mms figure, the rest looks fine.
What is not fine is the unknown frequency response. Unless it is ruler-flat with a very gradual and gentle rolloff with no peaks anywhere, you're on your own with the crossover. The basic concept with the Ariel was to chose the flattest and quickest CSD-decay drivers I could find back in the early Nineties, build an oversized MTM minimonitor around them, and arrange the efficiency of the paired midbass drivers so the tweeter wouldn't need to be attenuated.
As for the crossover, I voiced it with a slight "BBC dip" and a gentle tilt from bass to treble. That's pretty much it. Not a complicated system conceptually, and the many versions of the transmission line never sounded all that different from each other. I don't think all the complexity was warranted; I ever did a TL again, it would be much simpler.
I think it is basically impossible to build a good-sounding speaker without instrumentation - well, I couldn't do it, and I don't know anyone who can. The final "voicing" is done AFTER the system is measuring reasonably flat, NOT before, otherwise you'd endlessly go around in circles, never getting close to the optimum. There are many ways to build it wrong, but only a few to build it right - and professional speaker designers endlessly argue about which parameters to optimize.
Old 19th October 2008, 02:36 PM   #4550
Default drivers for my ariel5s project
hi Lynn,
I am absolutely delighted and thankful for your prompt reply and suggestions... the moving mass Mms was 7.8 grams....that was an error ... I am attaching the complete data with the frequency response.....kindly advise...i am ever greatful to you...a man of iconic stature to reply to a diy novice like me....
Beyond the ArielHide this!Advertise here!
