Beyond the Ariel
Beyond the Ariel
Old 1st October 2008, 09:34 AM   #4491
caninus80 is offline caninus80  Poland
It is not mine
Ask Martin...
Old 1st October 2008, 10:13 AM   #4492
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Beyond the Ariel
Nice postage cost arrangement then. Really economic, Lynn. They are magnificent looking pieces and heavy guns in your arsenal.
Old 1st October 2008, 10:27 AM   #4493
john k... is offline john k...  United States
john k...'s Avatar
Hi Lynn,
Been following along silently. When you have the compression drivers mounted to the horns would you be so kind as to post the resulting impedance measurement? I'm curious to see what it looks like.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 1st October 2008, 03:02 PM   #4494
John_E_Janowitz is offline John_E_Janowitz  United States
Send a message via MSN to John_E_Janowitz
Originally posted by Lynn Olson
I'm looking closely at 2 or 3 of the AESpeakers Dipole 15's per side in a close-fitting array, with the Selenium 15PW3's as an alternative. If anyone from AESpeakers is reading this, what are the Xmax, Qts, Fs, normalized efficiency, and pricing of the Dipole15's again? Can't find it on the AESpeakers website right now.
Hi Lynn,
The info on the Dipole15's can be found on the archive page here:
http://web.archive.org/web/200302141.../DIPOLE15.html
Fs: 21.7hz
Qms: 15.2
Qes: 1.0
Qts: .94
Vas: 623L
Cms: /7mm/N
Mms: 90g
sd: 855cm2
Rms: .81Kg/S
Bl: 12.2Tm
Re: 12.3ohm
Z: 16ohm
Le: .15mH
Pe: 200w
no: .61%
1wSPL: 90.1dB
Xmax: 12mm
This drivers uses a 14mm long coil in a 38mm tall underhung gap. If you look at a BL curve, you have very good linearity all the way out to 12mm each direction and about 2mm more before you hit 70% of the rest BL value.
I'll be doing some experimenting soon with a pair of Dipole15 per side and our new 6.5" midrange. I'll be adding in the B&G Neo3 planar as the top end as it can also be used as a dipole when removing the cup.
We had a small price increase of $30 to all Lambda drivers in mid august. The 15's are now all $309. There is still a $50 per pair discount as caninus80 mentions.
John
Old 1st October 2008, 03:39 PM   #4495
skorpion is offline skorpion  Sweden
Excuse my ignorance but what is the Magic about these Selenium15PW3s ? As I see it they will have extremly difficult to produce real low bass ?
/Erling
Old 1st October 2008, 08:59 PM   #4496
Lynn Olson is offline Lynn Olson  United States
Lynn Olson's Avatar
Default Results of Bjorn Kolbreks' BEM simulations
Here are Bjorn Kolbrek's first BEM simulations for the AH-160 (T=0.8) Azurahorn, which took 14 hours of run time. Bjorn is currently working on more simulations of the other models, and has given me permission to re-post his data here at DIYAudio.
The first graph is the polar response of the AH-160 from 100 Hz to 3 kHz.
Old 1st October 2008, 09:03 PM   #4497
Lynn Olson's Avatar
Default AH-160 Power Factor
The black line is the power factor (power going into the horn and then radiated into the room), and the red line is the percentage of power reflected back to the diaphragm.
Old 1st October 2008, 09:48 PM   #4498
John Sheerin is offline John Sheerin  United States
Default Re: Results of Bjorn Kolbreks' BEM simulations
Do you know how much of the driver that model includes?
Old 1st October 2008, 09:53 PM   #4499
Lynn Olson's Avatar
No, I don't. Bjorn Kolbrek is now working on the AH-425 with and without a model for the 288 throat profile, so I would guess the graphs AH-160 shown thus far are probably showing the response of the horn by itself.
Here's the model for the AH-160 throat impedance, showing the resistive and reactive terms.
Old 1st October 2008, 10:03 PM   #4500
Salas's Avatar
Beyond the Ariel
So its a 40deg symmetrical dispersion horn at 3kHz? How high are you planning to go with it?
Beyond the ArielHide this!Advertise here!
