#4201 | |
(The rest of the specs look really great! What are the proposed dimensions for the exterior diameter, baffle cutout, and bolt-circle diameter?) The general idea for this system is for the sub and the supertweeter to extend the response, but not be essential for musical enjoyment. The real system is the 18" woofer, the 12" midbass, and the large-format compression driver on a low-diffraction horn/waveguide. |
#4202 |
diyAudio Chief Moderator
Are you considering to use multiple and differently tuned self powered cheap subs and utilize overlap with the mains so to have an even modal region a la Geddes practice? Its a very good option to consider, IMHO.
#4203 |
More than one, that's for sure. But that's for much later. The frequency range that really matters is 50 Hz to 12 kHz, with a little extra sparkle on the top a nice bonus.
#4204 |
Even more tightly, 80Hz to 10kHz. I agree. But in a large room with a high SPL system, an even and deep modal region lends a royal sense of majesty. Imagine the Great Gate Of Kiev reproduced like that.
#4205 |
Well, that's certainly true. Very few systems can reproduce that astounding sense of bass rolling around that you hear in a big, beautiful symphony hall - thrills aplenty in "Pictures at an Exhibition", "Carmina Burana", or the "Rite of Spring".
Not the same as dinosaur thumps or a phaser blasts from a 7.1 Dolby Digital soundtrack in a multiplex theater. That's noise, not bass. |
#4206 |
And in Mahler's 2nd and in Holst's Planets, and in Stravinsky's Firebird, and, and...
#4207 | |
In the ''System'' concept I would certainly give paramount importance to the room factor and the way that it is energized. Evenly is the key. The rolling, enveloping, breathing bass of the huge concert hall is due to the fact that in such dimensions, the modal region stops low, at 10-20Hz. Higher than that, the modes become dense, much like they become in a domestic room after 150-200Hz. |
#4208 |
The 18Sound 12NDA520 Neodymium-magnet 12" driver is in the foreground, and the GPA 414 Alnico-magnet 12" driver is in the background. |
#4209 |
The 12NDA520 is in the foreground, and the 414 is in the background. |
#4210 |
Wow! Very nice woofer constructions. You are near to some serious hands on evaluations.
